Thread: Freezer Doors Shattering
30-05-2005, 10:57 AM #1
Can anyone help me with an explaination for tripple glazed freezer doors shattering the outside heated glass pannel.
The unit is an eight door Tyler 6ZWF3-FFC manafactured in USA and purchaced second hand by my customer.
The unit shattered one door about two months ago and it was put down to one of those unfortunete hapenstances but now I have been informed it has broken another one.
The outer pannel has active and neautral fed to either end and I assume works on the resistance of the glass to heat up the rails are being fed with 240volt, on some doors it much hotter on the ends near the feeds than it is in the middle any help or ideas greatly appericiated as I have only seen one issolated incident of this before when a tripple glazed door was left out in direct sunlight. Both these doors went undercover.
30-05-2005, 11:51 AM #2
Re: Freezer Doors Shattering
Is the glass tempered..if not it will more than likely shatter..tempered shatter proof glass is usually ok
100% is possible 100% of the time
30-05-2005, 01:54 PM #3
Are you sure nobody is hitting them with a trolley or something?
or is the door being slamed?
The outer pannel has active and neautral fed to either end and I assume works on the resistance of the glass to heat upIF AT FIRST YOU DON`T SUCCEED.
and go get a cuppa
30-05-2005, 07:32 PM #4
In supermarkets glass always breaks without any reason, Evaporator fanmotors mysteriously fill up with water, Evaporators start to leak throug big punktured holes an there never is a butcher around who knows how to remove ice witch a big axe, Sidepanels next to the door to the storache area just fall of the cabinets, drain are abolutly totaly clogged with massive amount of dirt and they claim that the draintray is cleaned at least once a week.
Well as we all probably know this list is endless.
But once a year in the week, if possible the day before christmas, then it is my day.
I JUST WANT ONLY FREEZER PROBLEMS, AND EACH AND EVERY ONE HAS TO BE COMPLETLY EMPTY IF THEY WANT IT FIXED
Victor
walk in freezer refrigeration sizing?
By trammd in forum Technical DiscussionsReplies: 10Last Post: 02-11-2006, 12:56 PM -
It's snowing in my walk in freezer!
By Matt in forum CommercialReplies: 19Last Post: 14-10-2006, 07:07 AM -
Freezer operation in my garage
By sonjand in forum FundamentalsReplies: 5Last Post: 02-08-2006, 10:25 PM -
please help with Kenmore Upright Freezer
By lrn376 in forum Trouble ShootingReplies: 0Last Post: 09-07-2006, 10:40 PM -
Fan quit in freezer compartment.
By odam2k in forum Trouble ShootingReplies: 4Last Post: 05-07-2003, 02:18 PM
