Thread: Acraclad coating
Hybrid View
24-05-2005, 12:28 PM #1
Acraclad coating
Hi guys
what effect will acraclad coating(on coil) have if there is ammonia in atmosphere. Also i know acraclad coating is anti coorosive and protects coil from moisture effects but i wanna learn more
regards
Ali
Our nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
24-05-2005, 01:51 PM #2
Re: Acraclad coating
Ali, the only info I can is www.polybond.co.uk/acron/Index.htm .
Maybe an email to them will get you more information.Last edited by Brian_UK; 24-05-2005 at 01:56 PM. Reason: Link error
24-05-2005, 03:51 PM #3
Hi Ali,
Are these coils for cheese storing?
Chemi
25-05-2005, 10:10 AM #4
well actually its a chilled water coil with acraclad coating on it and client says that process room contains air with NH3 (ammonia) traces in it
so he wants us to tell what effect acraclad coatin have on ammonia or vice versa
regards
AliOur nose is our personal air-conditioning system: it warms cold air, cools hot air and filters impurities
25-05-2005, 02:47 PM #5
Hi Ali.
I did once a cold store for goat cheese and the air is "full " of amonia.
Tried with Blygold and it lasted for only one year.
The best result that works fine for 4 years now is spraying epoxy paint into the coil with high pressure spraying gun.
At least 4 coats.
It should do the job.
Chemi
01-06-2005, 11:28 AM #6
tell me what effect will epoxy paint have on heat transfer capability aluminum fins when they are coated with epoxy paint
