Results 1 to 22 of 22
    Mar 2004
    624
    21
    H.P switch testing
    How do you all test H.P. switches and do you consider slowly winding in the H.P. valve as a safe method of testing.
    Many thanks
    Bernard
    Oct 2004
    Scotland
    1,454
    21
    Re: H.P switch testing
    Hi Bernard,
    I would use nitrogen to test them.
    I think that winding in the comp head stop valve would be a big no no . What would hapen if the h/p switch didn`t work and youre hanging over the comp with youre ratchet in hand trying to open it back up again and the hose burst?
    remember ..... be safe (get the app to do it lol)
    and go get a cuppa
    Jul 2004
    52
    64
    Cane use ofn to test the switch, or a hand pressure pump form H.R.P. I always use ofn its alot better, plus can see on the hp gauge what it trips at.
    Oct 2001
    Nottingham UK
    5,667
    Hi Bernard
    Most of the posts refer to testing the HP prior to fitting but you do need to soak test the HP every year during maintenance inspections. To do this we bypass the stat and let the compressor run until the HP trips. Adjustments are sometimes made to set the correct cut out dependant on the gas used.
    Jan 2003
    East Anglia
    1,160
    Hi Guys,
    I always check with OFN if fitting one, but for one that's already in use what you can do is set the switch lower than it's normally set at eg 300psi PSI on 404 and either cover the condenser or SLOWLY !!! front seat the discharge to see if it cuts out and check the calibration at a more sensible level. Then if it works at the set cut out you can re-adjust it.
    Fatboy
    Jan 2004
    Quebec,Canada
    10
    I consider slowly winding in the H.P. valve is a safe method.
    You can actually control/raise pressure couples pounds at a time.
    Dec 2004
    Australia
    52
    519
    I would use nitrogen to test new HP switch.
    Also cover up condenser to bring in fans,and test HP switch, this is simulating proper running conditions.Also use this method to check thermal overload suspected of tripping prematurly.
    Quick check wind in discharge service valve. Make sure gauge is connected to keep eye on pressure.
    Apr 2005
    INDIA
    63
    84
    Talking Re: H.P switch testing
    Mr, Bernard.
    connect the H.P switch to nitrogen cylinder which
    must have a max 300 psi regulator ( guage connected.)
    slowley open the regulator for requred pressure and set
    the switch , Is it easy ?
    beni joseph.
    Mar 2004
    624
    21
    Hi all
    I have always used ofn in the past but I recently had about 20 switches to test so I wound in the hp valve,I,ve been told there is a internal safety valve within the compressor which will pass straight into the suction if there is any problems.I suppose the advantages of not using ofn is less things to disconnect so less chances for leaks.Does anyone know at what pressure the internal valve works.
    Regards bernard
    Oct 2003
    5,630
    34
    http://www.refrigeration-engineer.co...=bypass+scroll from 09-09-2004, hey...my wedding date
    Mar 2004
    624
    21
    Hi peter
    I don,t understand what you mean please can you explain
    Regards bernard
    Oct 2003
    5,630
    34
    Quote Originally Posted by bernard
    Hi peter
    Regards bernard
    What? My wedding date? LOL
    No, if you read through that thread, you will find the answers for your questions, at least for the scrolls compressors.
    Mar 2004
    624
    21
    Hi peter
    Sorry my fault,this time I was refering to recips,I believe if the pressure gets to high that there is a valve inside the compressor that will blow and send the discharge straight into the suction?
    Regards Bernard
    Jan 2005
    Norfolk, U.K
    44
    65
    the grasso comps i have on site have an overfow safety valve (releif valve) which opperates at 22.5 bar and as you say, it allows the discharge to bypass into the suction.
    We normally test our pressure switches every 6 months, testing the hp by closing the dicharge valve slowly.
    system using R22, hp cut out set to 17bar
    Jun 2002
    628
    23
    Hi.
    Using OFN you have the risk of pushing non condensibles into the sytem.
    Testing adjustable switches can simply be done by dropping cut out below operating pressure,this will prove the switch is wired correctly and generates an alarm.As well as the switches contacts breaking.
    I would be reluctant in winding in discharge valves to test switches.
    Best regards. Mark
    Jun 2002
    628
    23
    Hi.
    Using OFN you have the risk of pushing non condensibles into the system.
    Best regards. Mark
    Oct 2002
    28
    to test h.p switches i usually just isolate/disconnect the condenser fans.
    p.s what's ofn?
    May 2004
    61
    48
    hi adam, ofn stands for oxygen free nitrogen or white spot as I used to call it. As you know it is an inert gas and being totaly moisture free it is ideal for testing hp switches, stopping oxidisation whilst brazing and good old pressure testing. dill. ps, as mentioned it is vital that all of it is removed from the system after use as it does not condense well and is brilliant at picking up water.
  19. #19
    Oct 2001
    Nottingham UK
    5,667
    Adam
    Have a look here http://www1.boc.com/uk/sds/
  20. #20
    Oct 2002
    28
    yeah, we just call it dry nitrogen. cultural differences
  21. #21
    Jun 2002
    628
    23
    The risk of non condensibles through using OFN on a pack via valves letting by,does not warrant the risk.
  22. #22
    Sep 2003
    ISRAEL
    72
    4,248
    I usually disconnect the condenser fans, pressure climbs slow and its easy to follow the increasing pressore.
    HP controlls should be tested at work conditions and not in a lab.
    chemi
  1. Pressure testing for leaks on split a/c systems
    By mrchatts in forum Air Conditioning
    Last Post: 08-04-2010, 10:02 AM
  2. flow switch connection
    By afeef in forum The Trail of Tears
    Last Post: 23-12-2009, 06:55 PM
  3. RCV and HIGH PRESSURE SWITCH
    By abbasi in forum Fundamentals
    Last Post: 22-03-2006, 08:51 AM
  4. shower switch fault !
    By Krups in forum Electrical
    Last Post: 19-10-2005, 09:10 PM
  5. Oil Pressure Switch
    By Abe in forum Commercial
    Last Post: 15-03-2003, 11:18 AM
