Results 1 to 2 of 2
24-07-2010, 06:15 PM #1
Air-Cooled_Low Discharge Superheat Alarm
McEnergy Air-Cooled
Both unit is for stand by use only. When the fresh start signal sent, "low discharge superheat" alarm occur only on circuit #1 after 30 minutes. After alarm reset, everything back to normal. apply to before it trip, manually switch off and then switch on back. Anyone got this kind of problem?
25-07-2010, 09:08 AM #2
Re: Air-Cooled_Low Discharge Superheat Alarm
to be sure you have to measure the super heat , discharge temp.
is the unit equiped with electronic exp device ?
if so check the lp temp sensor.
good luck
Carrier Transicold Container Problem
By Shamel in forum TransportReplies: 39Last Post: 23-01-2012, 11:23 PM -
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Carrier 23xl chiller-Low discharge superheat alarms
By Bradysmill in forum Trouble ShootingReplies: 7Last Post: 25-04-2010, 07:43 PM -
19XL High Discharge Temp intermittent alarm at compressor start
By pete_d in forum CommercialReplies: 5Last Post: 08-11-2009, 05:10 PM -
discharge superheat
By philjd26 in forum Trouble ShootingReplies: 8Last Post: 09-01-2008, 07:48 AM
