Results 1 to 2 of 2
Thread: Ref. circuit
16-05-2005, 04:37 PM #1
Ref. circuit
Hi everybody
I have some questions, I hope to find answers from yor experiences
I am working on R134 chiller with water cooled condenser and flooded evaporator (water in pipes and ref outside), also on other chillers with R22 with air cooled condenser and DX evaporator(ref in pipes and water outside)
I can not determine how much to be the condenser and evaporator approach, what difference between R134 and R22 and how it is relating to the type of evaporator and condenser.
Also how I determine the cond press and temp regarding to atmosphare or water temperature, the same for the evaporator
Discharge temp how relates to condenser temp
please help
31-05-2005, 12:24 AM #2
Re: Ref. circuit
I am not sure that I understand what you are asking for. Do you want to be able to measure these values on a system that is operating or do you want to know general values for sizing or troubleshooting?
Generally, for sizing equipment, we use 10F or 5K for the approach in the evaporator or water cooled condenser and 20-25F or 12-15K for the approach in the air cooled condenser.
These are general numbers and specific equipment can need different numbers.
Brian Inman
Oil cooling circuit on Danfoss compressors?
By The MG Pony in forum FundamentalsReplies: 15Last Post: 16-10-2010, 12:33 PM -
Burst evap/water in refrig circuit, need suggestions for clean up
By Arkma in forum Trouble ShootingReplies: 16Last Post: 09-03-2006, 12:39 PM -
refrigeration circuit symbols
By neil sailes in forum FundamentalsReplies: 4Last Post: 23-06-2004, 08:09 PM -
Alternating Relay Circuit
By herefishy in forum IndustrialReplies: 3Last Post: 09-07-2002, 06:03 PM -
Twin Circuit RTU Humidity Control Modification
By bernie in forum Trouble ShootingReplies: 40Last Post: 18-03-2002, 12:41 AM
