    ramachandrasg's Avatar
    ramachandrasg Guest
    Clean room ac load calculation
    How to arrive cooling load for clean room.
    For example: If clean room requires for certain air changes (100% FResh air) is say 10,000 CFM and room to be maintained at 73 Deg F. and outside air temperature is 96 deg F DB and 62 Deg F WB.
    Pls help how to arrive cooling load in TR for this??
    Jun 2009
    Scotland
    34
    Re: Clean room ac load calculation
    To determine the load you can use the following:
    [Enthalpy Outside Air- Enthalpy Inside Air] x Specific Gravity of Air x Vent Rate.
    As we use the SI system the conversions are as follows:
    10,000 CFM = 6990.108 meters cubed/hour
    96F = 35.6C
    62F = 16.67C
    74F = 22.78C [Since you have not stated RH = 50%]
    Spec Gravity of Air = 1.2
    Enthalpy Ouside Air [CIBSE Guide] 46.901
    Enthalpy Inside Air [CIBSE Guide] 44.869
    From formula above:
    [46.910-44.869] x 1.2 x 6990.108 = 17120.173 KJ/h
    Converting to Kw = 4.756.
    tmm
    Oct 2001
    Nottingham UK
    5,668
    Quote Originally Posted by ramachandrasg View Post
    The total cooling load will need to be calculated to deal with building fabric gains, occupancy, lighting and equipment gains in addition to the ventilation load.
    Without further information from you it will not be possible to advise you correctly.
    I make the 100% fresh air load to be 106kW with a dt of 13K
    10000cfm = 4.719m3/s
  1. load calculation
    By nonoy0041@yahoo in forum Supermarket Refrigeration
    Last Post: 14-11-2009, 08:30 PM
  2. clean room heat load
    By pramodpatil in forum Air Conditioning
    Last Post: 26-01-2009, 09:41 AM
  3. Heat transfer coefficient - Coolpack
    By Graham in forum Fundamentals
    Last Post: 28-05-2008, 01:08 AM
  4. Compressor loading, cooling, and range of operation.
