    Jan 2004
    Rotherham/uk
    12
    Talking flywheel Bushes on SL 300
    Hi Reeferjon
    I have just had the opportunity to replace the flywheel Bushes on SL 300 I know you're thinking that's not so special which isn't having completed this task over at number of years on other TK products, what was different the reaction of other engineers at the parts counter a lot of sharp intakes of breath and don't forget to do this and don't do that with regard to refitting the compressor perhaps you can shed some light on what the problem is.
    However the job did go well as I followed all recommendations I was given.
    Martin
    Nov 2001
    Shropshire
    59
    260
    23
    Re: flywheel Bushes on SL 300
    Basicly the requirments are.
    1. Don't preload or impact the pump at all.
    2. Make sure you refit the clutch in the correct manor.
    3. Prime the pump (a lot!).
    4. Make sure the bushes slide on the pins (as in slide easy).
    5. Oh and don't preload or impact the pump at all
    John.
    andy towle's Avatar
    andy towle Guest
    hi jon
    did you mention buhes only 30,000 more to do!
    Nov 2001
    Shropshire
    59
    260
    23
    29,999
    29,998
    29,997
    29,996
