Thread: Crankcase Heater Failure
08-07-2010, 12:40 PM #1
Hello,
New to re site,
I was replacing a Carrier 06-E compressor and found that the crankcase heater, (plug into sump type) failed overnight. I checked it that afternoon all ok and found it not working and open cct the next morning. I had the system with oil to the base of the sightglass, and had left the system under vacuum overnight ready to charge the next day. It was a very old heater id say 15 years plus.
My boss has now advised me to leave crankcase heaters off while evacuating a system? Any truth to this? I would have thought its best to leave them on.
Cheers, James
08-07-2010, 02:46 PM #2
Re: Crankcase Heater Failure
i wouldn't have thought it would make a blind bit of a difference to be honhest!!
08-07-2010, 04:29 PM #3
08-07-2010, 06:47 PM #4
09-07-2010, 07:15 AM #5
Come on. Eveybody knows that the vapour pressure of refrigerant is a function of temperature. The higher the oil temperature, the better the vacuum.
It's written in each and every manual of compressors: keep the heaters on while evacuating.
RTFM!
11-07-2010, 11:02 AM #6
Thanks guys, with some bosses, even when your right, your wrong. Will keep heaters on when pulling vacs anyways, thanks James..
Carrier Transicold Container Problem
By Shamel in forum TransportReplies: 39Last Post: 23-01-2012, 11:23 PM -
Crankcase heater?
By lomb in forum Heat PumpsReplies: 11Last Post: 09-07-2011, 03:23 PM -
Single pole contactor & crankcase heater
By herefishy in forum Air ConditioningReplies: 7Last Post: 01-04-2009, 08:38 AM -
Whirpool defrost heater
By frozen fred in forum DomesticReplies: 0Last Post: 27-01-2008, 06:41 AM -
crankcase heater thought
By philjd26 in forum Trouble ShootingReplies: 25Last Post: 30-06-2007, 10:46 PM
