Results 1 to 15 of 15
Thread: I.Q.Test
Threaded View
03-05-2005, 05:08 AM #13
Re: I.Q.Test
Originally Posted by Marc O'Brien
Anyway, you have some time, and instantly you look for patterns. In a number sequence, if the first number is a known prime, you check for primes. If the first is a known square, you check for squares, if the second is one third of the first you check for that.
Checking for all the usual suspect doesn't take time as this is done automatically. If the answer does come almost instantly, you can decide to rely on your intuition.
But what is intuition? The brain recognizes a pattern, you don’t see? This is certain to fail in cases like this. This is a calculated, constructed example, which doesn't lend itself to intuition.
It is my experience anyway, if I don’t see the pattern in this types of test, I likely get it wrong.
Saludos
