01-07-2010, 03:05 PM #1
MCQUAY reciprocating compressor needed.
Working as ac tech for a contracting company , worked on york , trane refcomp, carrier compressors, this is the first time i m assigned a mcquay comp.Previous tech said, comp has mech problem, inspested found shaft worn out, pistons scrached , looks like comp had run on low lubrication.In need of compressor manual for tollerances and torque values.MQC-S 800 & 900 type reciprocating for ref 22 and 407c
01-07-2010, 09:36 PM #2
Re: MCQUAY reciprocating compressor needed.
hi muju the the mains are 75mm (.010)(.025) and the journels are 70mm , if the crank is worn then you cant get over sized rod shells or main bearings because they are supplied standard the winding housing has to be aligned properly and the air gap checked properly with long feeler guage all the way round between the stator and rotor about 27 to 30 thou , its very tricky ,other wise the you,ll get rotor rub and the heat will melt the main bearing on to the crank and it will be scrap ,any problems with the rebuild give me call and i will help you
15-07-2010, 10:54 PM #3
you should be able to contact them to get the service manual for this information
http://www.mcquay.com/McQuay/Literature/Literature
21-07-2010, 04:22 PM #4
I have as a pdf of the complete manual - not sure how we can get in contact without giving e-mail addresses or 'phone numbers out - is there a private message section?
23-07-2010, 11:00 AM #5
sorry had been out for project, my e mail add is muju_mahableshwar@yahoo.co.in, need any help with york units i'll be helpful. thank u, will be glad for ur help
23-07-2010, 01:25 PM #6
...just sent it - all the best...
23-07-2010, 02:56 PM #7
Thankyou for that. God bless u.
Aaaargh Mcquay!!!
By pb smash in forum ElectricalReplies: 13Last Post: 11-02-2010, 03:27 PM -
McQuay ALS F XE273.2 990Kw, highest return temp?
By THE WOMBAT in forum Technical SpeculationsReplies: 1Last Post: 07-08-2009, 10:59 AM -
Compressors - screw or reciprocating?
By Josip in forum Industrial CompressorsReplies: 18Last Post: 27-01-2009, 10:36 PM -
York Reciprocating Compressor
By lldelfin67 in forum Industrial CompressorsReplies: 0Last Post: 17-07-2007, 03:56 PM -
Hermetic reciprocating versus hermetic scroll
By Cofreth in forum Technical DiscussionsReplies: 26Last Post: 19-11-2005, 06:29 PM
