Thread: Mitsi Fault
30-06-2010, 09:50 PM #1
Mitsi Fault
Have a R407c Mr Slim unit showing a U1 fault on controller. Reset and went out to check condenser unit but found it is going into fault straight away after trying to start second time. Checked manual and says U1 is abnormal high pressure. Have linked out hp and unit still does the same. Tryed to start once then goes into fault with three green led flashes and then two red led flashes. System has gas in standing pressure 130 psi. Need to go back with scissor lift to check out properly. Noticed compressor was really hot in its jacket not sure but may this be because its not running and crankcase heater is on ? Think it may be a compressor fault but im not 100% Any help please thanks in advance
Transvestites are men who like to eat, drink, and be Mary.
02-07-2010, 05:32 PM #2
Re: Mitsi Fault
Recently had HP problems on single fan condensers, problem was fan blade turning on fan motor shaft because flat inside fan blade seemed to have melted and gone round. Just an idea.
02-07-2010, 07:18 PM #3
Re: Mitsi Fault
hi guys, i work on a certain hotel, restaurant chain, which have alot of R22 kit, which is under an R22 program, with regards to the R407c on these sites we are starting to replace most blades on the R407c systems as the shape of the plastic shaft is worn to a complete circle.
has any1 else experianced this.
02-07-2010, 08:30 PM #4
Re: Mitsi Fault
Hi Phil,
If the Hp switch (63hs) has been linked out and it is still showing a high pressure fault then i'd be looking at the outdoor circuit board.The difference between genius and stupidity is that genius has its limits.
Marc
Mitsi electric fault codes?
By weidit in forum Air ConditioningReplies: 15Last Post: 22-12-2009, 10:54 PM -
Mitsi Heavy Fault
By coolments in forum Air ConditioningReplies: 2Last Post: 22-09-2008, 09:18 AM -
Mitsi Electric RP6AA Pump Fault
By gwilliamson in forum Air ConditioningReplies: 8Last Post: 15-08-2008, 05:59 PM -
Mitsi Fault codes
By Matt_H in forum Air ConditioningReplies: 3Last Post: 08-09-2006, 10:00 PM -
Mitsi Fault
By richelli in forum Trouble ShootingReplies: 2Last Post: 27-03-2006, 07:20 PM
