Results 1 to 2 of 2
28-06-2010, 05:21 AM #1
Need Specs for Chiller Replacement
Hi All,
Need your help, What better specifications do i need for chiller replacement? I am here at the Makati Office having two tower office building with the height of 160 meters.
Currently:
We are using 5 Chillers
1,150 Tons capacity - 5 units
0.658 KW/Ton
I Need a repalcement of at least 0.350 to 0.450 K/Ton chiller input power
erwin
28-06-2010, 01:21 PM #2
Re: Need Specs for Chiller Replacement
Hi erwinolivares
I must assume you mean output. You could look at a few of the danfos turbo cor chillers and compare with a trane centrif or a few screws. That's around fifty stories so you may need a high pressure (water) chiller depending on how much head above the particular chiller. Of course you will need to take into consideration the experience and level of service you may get from local contractors.
Trane will give you bang for your buck and reliability, where the Turbo cor will give you efficiency (dependent on ambient conditions.
R22 replacement
By brad__34 in forum RefrigerantsReplies: 28Last Post: 04-06-2010, 09:06 PM -
carrier phoenix advantage specs
By west texas in forum TransportReplies: 5Last Post: 26-06-2009, 06:12 PM -
Blind Cold room specs help
By frostedflake in forum Trouble ShootingReplies: 5Last Post: 13-03-2009, 01:49 AM -
Replacement Screw Compressors
By dkemper in forum Technical DiscussionsReplies: 2Last Post: 13-10-2007, 07:22 PM -
F 11 replacement for flushing
By andrewuk in forum RefrigerantsReplies: 1Last Post: 17-10-2003, 11:03 PM
