21-04-2005, 09:39 AM #1
zone heating /cooling work station
Hi Sirs
I attatched a photo of one zone heating /cooling work station.
I'm not sure what valve it is between safety valve and pressure tank and what function it plays. who can teach meabout it? thanks in advance!
rgds
lichuan
21-04-2005, 09:45 AM #2
Re: zone heating /cooling work station
sorry attach again
21-04-2005, 03:32 PM #3
I agree with Mark , it should be the service valve for the expension tank , it is used to isolate it from the system in case of maintenance or replacement work.
21-04-2005, 03:38 PM #4
The main valve is an isolation valve to allow for servicing of the expansion vessel, the second, downward facing valve is a drain valve.
You would need to isolate the expansion vessel to check the cold fill pressure etc.Brian - Newton Abbot, Devon, UK
21-04-2005, 08:37 PM #5
It's correct but don't forget to re-open it afterwards.
21-04-2005, 11:36 PM #6
Originally Posted by Peter_1
Good point Peter; there goes next weeks call backBrian - Newton Abbot, Devon, UK
22-04-2005, 01:26 AM #7
thanks for your good idea.
the valve is a integrated one (with both cut off / drain function). I've taken the point.
will invite you to have tea while you come China
rgds
lichuan
Prison vs Work
By Abe in forum Chit Chat & Service StoriesReplies: 11Last Post: 06-09-2010, 08:47 PM -
part p
By eggs in forum ElectricalReplies: 25Last Post: 15-11-2007, 08:55 PM
