Results 1 to 2 of 2
    praglen's Avatar
    praglen Guest
    Need Sizing Info
    I have a 10-year old A/C unit(fan and compressor) in my bedroom, which has died.
    Although the plate says it is 20,000BTU, it is so old I suspect today's A/C units require fewer BTUs. For example, the compressor is encased in a heavy metal case, measuring 39" x 22" x 12" and the fan/control unit is 39" long,etc.
    The room dimensions are a total of approx. 1100 cu.ft. What size unit do I need and is there something else I need to know(the seller will install the new unit, including supplying the *****).
    Mar 2007
    118
    Re: Need Sizing Info
    Did the 20,000 BTU do what you wanted it to do? If so the BTU rating will not change. Chances are a modern unit will be more compact.
  1. A/C Chiller Sizing tables
    By romaurie in forum Tools and Calculators
    Last Post: 12-12-2010, 01:04 PM
  2. Capillary tube sizing
    By Sledge in forum Refrigerants
    Last Post: 16-11-2010, 11:44 PM
  3. DORIN Comporessor Info Needed
    By MikeySq in forum Commercial
    Last Post: 17-11-2009, 11:25 AM
  4. Need info on the shaft seal system for scotsman
    By The MG Pony in forum Commercial
    Last Post: 17-03-2008, 02:02 AM
  5. Sizing for Australia
    By dogma in forum Fundamentals
    Last Post: 17-03-2006, 10:05 AM
