Thread: Supra 844
19-05-2010, 11:59 AM #1
Supra 844
Supra 844 showing code 'Alt Aux' and yet alternator is putting out 13.8 volts. Any ideas?
Also does anyone know part numbers for 'spurious' filters for this unit?
19-05-2010, 12:19 PM #2
Re: Supra 844
Is it voltage on the D+ terminal at the alternator. And is the D+ wire properly connected to this terminal? There has been some problems with loose spade type connector on the D+ terminal on older supras. You can also connect the D+ wire to the small 4mm diameter D+ screw instead of the D+ spade type connector directly on the regulator/brush assembly.
19-05-2010, 09:46 PM #3
Re: Supra 844
No charging alternator (check the alternator belts and cable connections).
01-06-2010, 08:29 PM #4
Re: Supra 844
Problem turned out to be dodgy alternator!
Thanks SteinerN and Radekklimat
Carrier Supra 444
By ddocwra in forum TransportReplies: 14Last Post: 30-04-2010, 06:52 AM -
Carrier Supra 650
By Jwatdtr1878 in forum Trouble ShootingReplies: 0Last Post: 26-06-2009, 12:44 PM -
Supra 644 Cab Command readings?
By truckman in forum TransportReplies: 5Last Post: 04-05-2009, 06:02 PM -
Carrier Supra
By Vernon in forum TransportReplies: 6Last Post: 05-07-2008, 07:39 AM
