Results 1 to 8 of 8
Thread: BEKA capillary tube mat system
01-04-2005, 09:58 AM #1
who have used BEKA (Germany)capillary tube mat cooling system ? I need to know the control ways of the system. thx in advance!
01-04-2005, 10:33 AM #2
Re: BEKA capillary tube mat system
What are they fabricating? Didn't found their website.
01-04-2005, 12:28 PM #3
Is it something like this:
http://www.heka-eu.com/
Lol, I feel like I'm in a quiz show
Chemi
01-04-2005, 12:36 PM #4
At last,
www.beka-klima.de
And yes,
the previus post was a bull's eye.
Chemi
02-04-2005, 12:42 AM #5
Chemi,Peter,
thx!
Yes. i see it.
It seems not well known company in Europe.i'm not sure if their product are widely used.
rgds
lichuan
02-04-2005, 08:06 AM #6
Hi lichuan,
I'm not sure about it at all, but first I want to read about it.
Condensation is what I am worried about.
Chemi
02-04-2005, 05:26 PM #7
I saw it a few times on an exhibition.
Condensation is prevented by a dewpoint control.
The capacity these systems gives is not always sufficient to meet the needed cooling or heating loads. Additional heating must be installed.
They install it also on the walls. I wonder how you have to hang a painting afterwards.
I don't like this system for space heating because heat must be added as low as possible in a room.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
21-08-2009, 01:58 PM #8
Hi, I'm Project Manager for Capillary tube system (from Beka company). We are (Hennlich.com) distributors for this system of heating/cooling. I must say It works perfectly even in administrative spaces as prefa-cassettes or if you use it as ceiling heatin-cooling system. No worries about raising hot air up, this system works as radiation system,t.m. all objects and floor in the room are heated-cooled by radiant heat. There's no need to double the system. Best connection is with heat pump. Look at g-term.cz, look at some references.Tomas Cerny
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
System Burn Out Troubleshooting
By altaf22m in forum Technical DiscussionsReplies: 13Last Post: 07-05-2010, 09:24 AM -
Burn out System, Clean up procedure. & Troubleshooting.
By altaf22m in forum CommercialReplies: 19Last Post: 15-04-2008, 07:03 PM -
metric capillary tube
By tralex in forum FundamentalsReplies: 5Last Post: 21-02-2006, 06:57 AM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
