Thread: blast freezer
    halhol90's Avatar
    halhol90 Guest
    blast freezer
    could anybody tell me anything about i want to make blast freezer with condensing unit hsn 7471-75
    Split Croatia
    57
    6,151
    36
    Re: blast freezer
    Blast freezer construction doesn't start with condensing unit. It finishes with it.
    Feb 2009
    telford
    2,090
    33
    Re: blast freezer
    more info needed,what size the room what type of product what is the temperature of the product,basically the heat load,ambient etc.
    Jun 2007
    South Africa
    66
    120
    Re: blast freezer
    HSN7471-75 is a Bitzer Semi Hermetic Screw Compressor. You still need an evaporator, condenser and all the necessary equipment and controls to make it work.
    This compressor can give 44.4 Kw at -45 Deg. C suction and 40 Deg. C Condensing with R 507A, based on 10 K suction superheat and liquid subcooling.
    So, you should be able to pull down 12000 kg of Sardines from 12 Deg. C to -25 Deg. C core temperature in about 14 hours.
    Freezer room size should be approximately 5 X 4 X 3.2 meter high to accommodate product and evaporator, with neccessary fans and false ceiling
    I am not always right, but I'm never wrong!
  1. Air blast freezer designation - limited space
    By Sien in forum Industrial
    Last Post: 14-12-2009, 10:13 AM
  2. Blast Freezer Within Freezer
    By rickmor in forum Technical Discussions
    Last Post: 18-06-2009, 03:37 AM
  3. Trolley freezer & blast freezer
    By smpsmp45 in forum NH3
    Last Post: 25-08-2007, 07:29 AM
  4. Blast Freezer
    By w.l.ong in forum Industrial
    Last Post: 16-12-2006, 10:34 AM
  5. Blast Freezer Questions
    By rickmor in forum Industrial
    Last Post: 11-04-2006, 08:15 PM
