Thread: bending pipe
17-03-2005, 06:45 AM #1
bending pipe
not a trick question..
what's your proceedure for bending 1/2 hard straight lengths of copper?
cheers
richard
17-03-2005, 06:49 AM #2
Re: bending pipe
Heating it with a torch to soften it in the region where you wanna bend it.
My experience is that if you don't do it, you can expect small cracks in the pipe or it may even crack completely.
Sometimes, I used a 5/8 bender for a 1/2 pipe.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
17-03-2005, 02:40 PM #3
Re: bending pipe
Hi Richard,
What Peter wrote, is the best way but I don't understand the part of using 5/8 bender.
1/2 bender will do the job just fine.
I use this method up to 11/8 pipes. For bending over 3/4, I use plastic pipe bender, it doe's the job after the copper was heated and left to cool.
Chemi
Pipe Branch reinforcement
By Camille in forum Technical DiscussionsReplies: 6Last Post: 06-01-2011, 06:25 PM -
pipe sizeing tool
By Latte in forum Tools and CalculatorsReplies: 5Last Post: 10-12-2003, 11:32 PM -
How many small strands needed to equal pipe pressure drop?
By DaBit in forum FundamentalsReplies: 17Last Post: 25-08-2003, 09:56 PM -
Pipe sizes
By benncool in forum Chit Chat & Service StoriesReplies: 10Last Post: 08-07-2003, 10:58 PM
