Results 1 to 2 of 2
Thread: Russel cond unit vcd-32h22
23-04-2010, 10:02 AM #1
The above cond unit is with the following compressors :
1) 3dasa 075e tfd200
2) 3df3a 120e tfd200
3) 3ds3a 120e tfd200
what would be the displacement of each compressor in meter cube per hour at 1450 rpm ?
23-04-2010, 11:22 PM #2
Re: Russel cond unit vcd-32h22
It's an interesting question I suppose but as you haven't given any indication of the prize for getting the answer right I will decline to provide information that you could get directly from the manufacturer.
Mind you, as you haven't give that information either it gets even harder to get the prize.Brian - Newton Abbot, Devon, UK
Vrv
By tgoonter in forum Air ConditioningReplies: 4Last Post: 11-01-2011, 06:25 AM -
Water leak on a daikin wall unit
By marc5180 in forum Air ConditioningReplies: 5Last Post: 27-08-2009, 07:23 PM -
chillwell display unit
By paulwild in forum CommercialReplies: 2Last Post: 16-02-2009, 06:59 PM -
New Toshiba unit won't start..?
By expat in forum Air ConditioningReplies: 14Last Post: 07-04-2008, 09:11 PM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM
