Results 1 to 2 of 2
Thread: Reversible filter drier
16-04-2010, 12:34 AM #1
I have installed a reversible burn out drier on the suction of a split which has had a compressor change(Mitsi)
what is the recommended/max time before we would have to remove the filter in your opinion.
19-04-2010, 11:24 PM #2
Re: Reversible filter drier
hi WC did you not fit a new liquid line dryer aswell? you want to change the suction dryer ? what is in the system to make you want to do this ? test the contaminets and if its still there fit a new dryer , you said you fitted a reverable dryer , why is it on a heat pump? so the liquid line dryer should be a heat pump burn out dryer also.
best of luck.= sedgy
filter drier with r290?
By partypalooza5 in forum RefrigerantsReplies: 8Last Post: 22-06-2009, 10:06 AM -
Filter Drier
By grego in forum New TechnologiesReplies: 6Last Post: 30-05-2008, 08:32 PM -
Filter Drier Moisture content
By caster in forum Trouble ShootingReplies: 4Last Post: 02-11-2007, 08:59 AM -
How is a filter drier sized
By kengineering in forum Technical DiscussionsReplies: 2Last Post: 08-08-2006, 05:00 AM -
Drier Position
By subzero*psia in forum CommercialReplies: 8Last Post: 23-07-2001, 10:28 PM
