Thread: Manitowoc ice machine
03-04-2010, 05:48 PM #1
Hello chaps, do any of you guys know what compressor should go in a manitowoc QRO 130A icemaker?
The compressor in it is a tecumseh, but I cannot read the label on top because of no clearance above the top - only about 20mm I did get a number but it appears to be the wrong one AE 590JT - 900- A4D.
I've tried a couple of manitowoc ditributors, but all they can tell me is that it is either a danfoss or tecumseh, and thats it. The manitowoc technical manual isn't any help either - again just danfoss or tecumseh.
So if any body know what model goes in, please let me know.
Andy
04-04-2010, 04:00 AM #2
Re: Manitowoc ice machine
The best way is by serial number of machine itself. Manufacturers change product choices in mid production run based on who gave best skid price if parts at that time. Also there are constant enginerring changes made during same model/year run. Seems engineers don't live by " if it ain't broke...don't fix it " rule. Look at filter dryer and, if Danfoss, you have good chance that's what was used that day. Factory tech support will be of BIG help in most cases. US phone # is 1-800-545-5720. Try email but will take longer. Address is www.manitowocice.com Good luck. Have a good one !!
Don't leave it like you found it.....Leave it like it should be !!!
22-04-2010, 05:28 PM #3
well people are from outside the US or other state might need to use the M60, Q47, Q48, Q72 and Q33 to get around the city, so how can there not be a vending machineTo bad the SI mall doest have one or parts of SI -_-b
23-04-2010, 05:58 AM #4
Re: Identification of compressor in Manitowoc ice maker.
The "AE590AT" is the Compressor B/M for the compressor in a Tecumseh commercial temp. water cooled condensing unit with a 1/4 hp-115volt R404A compressor.
The actual compressor model number would be AEA9422ZXA.
98% sure thats your compressor, however in the literature they say they are using a 1/3 hp compressor. But a 1/3 hp comp. would not have that B/M on it.
I guess you will find out when you remove it.
23-04-2010, 09:14 AM #5
Cheers Zpoint, thanks for the info.
Andy
Manitowoc Ice machine taking too long to harvest..
By nyTroX in forum Trouble ShootingReplies: 26Last Post: 08-05-2011, 09:39 PM -
locate aftermarket compressor 4a Q600 Manitowoc ice machine
By iceman6108 in forum CommercialReplies: 0Last Post: 11-03-2010, 04:07 AM -
Manitowoc Ice Machine
By crazycohiba in forum CommercialReplies: 3Last Post: 27-08-2009, 05:19 AM -
Manitowoc Q series Ice Machine
By JerryG in forum Trouble ShootingReplies: 8Last Post: 12-05-2009, 01:57 PM -
manitowoc ice machine harvest cycle
By flyboy3b in forum Trouble ShootingReplies: 9Last Post: 26-05-2008, 06:51 AM
