Results 1 to 9 of 9
    Oct 2008
    174
    Koxka display cabinet/multideck
    Hi guys i have a customer with a Koxka display cabinet, Mod - M-26-CUK, S no -N.958.219 R404A. The cabinet has the condensor underneath it (built in to frame), the customer has asked me to give him a price on fitting a remote condensor outside the shop to supply the cabinet as he has no AC in the shop and in summer time the fridge can struggle with the heat. Now this is a first for me so can anybody tell me if this will be efficient or is this a bad idea and might cause problems, if so can anybody give me the size of a suitable condensor for this (the pipe run will be about 10 metres) Thanks in advance
    Feb 2007
    newcastle but now carlisle
    195
    Re: Koxka display cabinet/multideck
    firts thing we need to know does it hav a tev or cap ?
    Oct 2008
    174
    capillary i think, can check it today
    Feb 2008
    adelaide sth.oz
    1,015
    why not fit complete condensing unit on roof and size piping to suit,unsure as you say condenser is built into unit frame,maybe remove components make your own base and fit an oil seperator if required.
    Oct 2008
    174
    Had a look at it yesterday, it has 2 condensor coils underneath it (1 compressor) with 2 capillarys going to evap coil, i would fit a new condensing unit outside and not bother with the old kit, i just need an idea of what size condensor unit to use and pipe sizes etc, also i will need to fit an exp valve. Seems like a bit of hassle to do but customer has twisted my arm so to speak.
    ireland
    1,451
    41
    Koxka should be able to give you the duty of the fridge,failing that you could match the compressors and uprate depending on length of pipe run.
    alec
    Feb 2007
    195
    fit a tev , cap no good if you fitting the condensing unit out side . wat size comp is on it now ? just get the same or a little bit bigger condensing unit .the case will hav a sticker on it telling you the kw ? and gas ? . never had that problem you have on them units . have you had comp problems with it ? might just need a good vac and gas change ?
    Oct 2008
    174
    Thanks for the info guys, will contact koxka first then go from there or will match it with similar size. The system itself works fine but the guys shop turns into a furnace in summer, theres a lot of kit piled into 1 small shop.
    Oct 2004
    Scotland
    1,454
    21
    Quote Originally Posted by Northdude View Post
    How about fitting 1 cond unit for the whole lot?
    Chillin
    and go get a cuppa
  1. Structual Concepts Display case and a phamtom fault
    By jimmylcoleman in forum Technical Discussions
    Last Post: 08-02-2010, 01:42 AM
  2. Hotpoint HME400N Fridge Freezer message on display:
    By back2space in forum Domestic
    Last Post: 30-01-2010, 08:14 PM
  3. Samsung RS21DCSV1 Flashing Display
    By leon in forum Domestic
    Last Post: 07-07-2009, 10:10 PM
  4. Wiring diagram for carrier cabine display
    By optomik in forum Electrical
    Last Post: 14-05-2009, 04:35 AM
  5. a frozen book display case
    By tempo in forum Technical Discussions
    Last Post: 15-08-2008, 07:20 PM
