Thread: Pre-EXpansion
12-03-2010, 10:11 PM #1
Pre-EXpansion
Hi, bit of a boring & stupid question for you guys. Can anyone tell me why some manufacturers employ a system of pre-expansion in the outdoor unit of their split air conditioning units? I can only assume that its more efficient than carrying out the expansion at the indoor unit? thanks
12-03-2010, 11:06 PM #2
Re: Pre-EXpansion
It keeps the high pressures all in one place.
13-03-2010, 08:56 AM #3
Re: Pre-EXpansion
A large segment of global sales of split systems is for domestic application & customer expectation for low noise level.
Pre expansion at outdoor unit helps reduce refrigerant noise at the indoor unit in cooling mode.
I think you may find that the total refrigerant charge for the system is also reduced when using outdoor unit pre expansion.
14-03-2010, 05:10 PM #4
Re: Pre-EXpansion
Thanks Thermatech, your solving all my problems HAha
Actual Expansion Valve Process
By AastroGuru in forum FundamentalsReplies: 11Last Post: 03-02-2009, 09:53 AM -
Setting of Hand expansion valve
By Iceehot in forum NH3Replies: 7Last Post: 10-09-2008, 01:25 AM -
How an expansion tank works?
By Raadster in forum FundamentalsReplies: 6Last Post: 25-07-2008, 02:25 PM -
VRV expansion devices.
By Markie in forum Air ConditioningReplies: 18Last Post: 14-04-2006, 07:20 AM -
Expansion
By alesindo in forum FundamentalsReplies: 11Last Post: 30-07-2005, 09:16 AM
