Thread: Bitzer screwpack vibrations
05-03-2010, 01:43 PM #1
I have a vibration problem at a Bitzer screwpack, always at screw nr.1 If that one go`s up to 75% - 100% there is a huge sound and vibrating in the suction line. The screw was inspected by Bitzer, we changed no2 on place of no1, we opend the suction line and inspected it with a endoscope all in to the evaporator, nothing helps.
Is it possible to mount a muffler in the suction line??
Thanks for any idea!!
05-03-2010, 02:33 PM #2
Re: Bitzer screwpack vibrations
Hard to say without a lot of details but it may be as simple as changing the length of a pipe or moving a T fitting to eliminate some sort of resonance.
05-03-2010, 02:42 PM #3
Require bitzer to replace or repair it. I don't see why you have to touch the system for a **** compressor.
Bitzer gasket
By Renato RR in forum FundamentalsReplies: 5Last Post: 04-11-2010, 10:08 AM -
Bitzer s6f30 2-stage compressors
By JONAH in forum Technical DiscussionsReplies: 25Last Post: 27-10-2010, 07:27 AM -
Bitzer CSH8561-125Y oil sight glass
By Peter_1 in forum IndustrialReplies: 40Last Post: 26-05-2010, 04:32 PM -
Oil pressure Bitzer
By coolcmt in forum CommercialReplies: 10Last Post: 25-09-2009, 07:09 AM -
Bitzer Screw Compressors
By Davezz in forum Industrial CompressorsReplies: 9Last Post: 09-02-2008, 09:32 PM
