04-03-2010, 03:55 PM #1
Carel / Zanotti setup sheet required
Hi guys, I am after a set up sheet for a Carel IRZNCR0021 controller as fitted to an old zanotti unit, the controller is badged zanotti on front but Carel on the label.
04-03-2010, 07:26 PM #2
Re: Carel / Zanotti setup sheet required
i got info from zanotti if you pm me i will try to send it to you
05-03-2010, 12:07 PM #3
Now fixed up by AFR, thanks anyway.
zanotti GM1 freezer coldroom set up sheet
By pafc in forum Technical DiscussionsReplies: 0Last Post: 22-10-2009, 01:35 PM
