Results 1 to 13 of 13
    Cool Degrees °C Centigrade
    I know quite a lot of people use the splat sign '*' to indicate the degree symbol and that's OK
    If you want to smarten up your post, email or whatever try using the following:-
    Hold down the ALT key and using the keypad numbers press 2, 4, 8.
    You can let go of the ALT key now and revel in the excitment of seeing the ° symbol ( ) pop up on your screen.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Degrees °C Centigrade
    Hi Brian,
    No can do.
    I have it set up in Office 2003 but it dosen't work here.
    Its the personal setting of the Signs in your computer.
    If you explain how you did it on your computer, maybe I can do it on mine.
    Chemi
    5,667
    Doesn't work for me
    Well it should, he says hopefully, because it is part of the ASCII code for symbols.
    Try holding down ALT (not ALT Gr) and tapping out a few three digit codes into the numeric (Num Lock on) pad and see if you get anything at all.
    If it don't work then I should have kept my mouth shut.
    Aug 2004
    744
    {}ô°°♪☻○◘╒▼■♥ woww!!!!!!
    you learn something everyday.
    cheers
    eggs
    Sep 2003
    ISRAEL
    72
    4,248
    OK eggs,
    Please explain slowly to a non English speaking person,
    How did you do it and I couldn't?
    Chemi
    Aug 2004
    744
    hello chemi.
    first press and hold "Alt"
    next press "2" release
    then press "6" release
    then "9" release
    lastly release the "alt"
    ♪ should appear.
    cheers
    eggs
    Sep 2003
    ISRAEL
    72
    4,248
    Sorry, Nope.
    What Windows version do you use and which is your Browser?
    It might have something to do with it.
    Chemi
    Aug 2004
    744
    ie6 and XP.
    Try MS Word, see if that works.
    ♂▬!B♥♠♦♣•█
    keep trying
    cheers
    eggs
    Sep 2003
    ISRAEL
    72
    4,248
    ♪ Now ° you ☺ say!!!? ♀Ω↔≈
    Chemi
    That heavens for that....
    I almost wish I hadn't started this
    Sep 2003
    ISRAEL
    72
    4,248
    Now that Marc helped me, here is the full table.
    Chemi
    May 2004
    Canada
    10
    In your windows system folder (usually c:\windows\system32), there is an executable called charmap.exe.
    Under XP, it can be accessed from :
    Start - All Programs - Accessories - System Tools - Character Map.
    Needless to say, creating a shortcut on the task bar or desktop or start menu will come in handy.
    Double click on the symbol you want to insert. Click on copy (it copies to the clipboard). Then paste ... and voila.
    OldWolf
  1. MP66 & Compressor Overheating
    By Intermez in forum Technical Discussions
    Last Post: 13-04-2010, 08:58 PM
  2. problem with split a/c
    By slothslag in forum Air Conditioning
    Last Post: 14-04-2004, 09:49 PM
  3. 90 degrees evaporator
    By coriolan in forum Industrial
    Last Post: 23-05-2003, 05:02 AM
  4. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
  5. temperature difference of evaporator coil
    By dantoubiana in forum Trouble Shooting
    Last Post: 03-05-2003, 03:46 AM
