Thread: Daikin h8 error
05-02-2010, 11:44 AM #1
Daikin h8 error
Hi, I've got a Daikin inverter a/c with an external model RX25HV1NB, which gives me an error code H8. I would appreciate if anyone can give me any troubleshooting tips before I change the external PCB. Note that it starts either in cold or hot modes and stops in a few seconds.On the external part the green and the next two red lights then remain on. Is there any way to check the current transformer or the thermistors?
05-02-2010, 07:53 PM #2
Re: Daikin h8 error
H8 refers to a fault with the AC input current sensor system or the current transformer or an associated abnormality.
Text the fault code to +447797801908 for details
06-02-2010, 03:14 PM #3
Re: Daikin h8 error
Dear frank, thank you for your reply, but this is where I am wondering what I have to check, is there something that usually causes such a malfunction?
07-02-2010, 08:42 AM #4
Re: Daikin h8 error
If you mean is there a common fault... the answer is no I'm afraid.
Daikin model ry71luv1 error J2 Outdoor Current sensor malfunction
By pab_gm in forum Trouble ShootingReplies: 3Last Post: 27-09-2010, 08:37 AM -
Daikin BRC1C51 Error code help
By monners in forum Trouble ShootingReplies: 1Last Post: 02-11-2009, 11:03 PM -
Fixing Daikin A3 Error
By Stuffy in forum Air ConditioningReplies: 3Last Post: 27-03-2009, 06:02 AM -
Daikin U4 error code
By Minty in forum Air ConditioningReplies: 6Last Post: 16-05-2008, 11:36 PM
