Results 1 to 24 of 24
Thread: Carrier Help Please
22-01-2010, 12:03 AM #1
Carrier Help Please
Hi there,
I hope somebody can help me. I was called to look at a carrier ac that was not responding to remote control. But if you pressed the test or emergency buttons it would start and run fine. I have found that there is a constant red flashing LED on the PCB of the indoor. I tried replaceing the IR circuit board but that has not helped. Next I shall try the Main PCB. Now I have a second Carrier Ac doing the same thing at another location. Can somebody please help me?
22-01-2010, 01:21 AM #2
Re: Carrier Help Please
Change the battery in the remote might help. They don't last forever.
22-01-2010, 08:08 PM #3
Model number ?
If I remember my limited Carrier indoor knowledge they can do that a lot without much help from the manuals.Brian - Newton Abbot, Devon, UK
31-01-2010, 04:20 AM #4
The Model is a 42g150hp (53g150hp) if that helps. I cannot find any manuals on it. Thanks for the reply.
31-01-2010, 04:24 AM #5
Changing the battery was the first thing I did. No joy there. I wish it was that simple.
28-02-2010, 07:17 AM #6
We have Carrier chillers Model: 30RA-200-BO244-PEE, supplied from M/s Carrier Africa. The problem is water penetrated to cooling circuit from evaporator(heat exchanger) recently 2 chiller units were malfunctioned due to same course. So, some please help me for assist to solve this problem. In Maldives Chiller systems having same problem, previously used RC chiller (Italy) as the happened I mentioned.
What are the factors I have to check?
28-02-2010, 08:18 AM #7
28-02-2010, 10:31 AM #8
its hard to find leak, becouse totally sealed the heat exchanger,there is noway to check for leak inside it.only we noticed system low pressure dropping & shutdown the cooling circuit
28-02-2010, 06:26 PM #9
My wife used to say you never listen to a word I say at least I think that what she said
28-02-2010, 07:20 PM #10
If pressure drops suddenly doesn't necessary means the RA has a broken evaporator.You should check the filter and also the sight-glass. Then if it froze up i think then you can do nothing about it.
28-02-2010, 08:21 PM #11
01-03-2010, 04:02 PM #12
4 chiller units breakdown of evaporator cracked & water penetrated to refrigerant (gas)circuit.
havent noticed any problem from hydraunic module.
the water we are using is desalinated,but its not acidic.
All Ineed to know motive of this issue.
whether it might acourse of water camistry?
In maldidives we having bad experience of using chiller system.
01-03-2010, 06:25 PM #13
01-03-2010, 11:35 PM #14
Hi again Have you had an analysis of the water to see if there is a reaction between the copper and steel in in the evaporator, also you may have to use water treatment in the chilled water
TooshMy wife used to say you never listen to a word I say at least I think that what she said
02-03-2010, 10:38 PM #15
11-03-2010, 07:58 PM #16
11-03-2010, 08:10 PM #17
11-03-2010, 11:52 PM #18
12-03-2010, 02:07 PM #19
Need to change the main PCB. I've never had a lot of luck repairing these things otherwise.
I learnt a few things here from nike about recievers and capacitors, those tricks work fine with mits and fujitsu units (solder in a new capacitor, and then a new reciever)
But with LG/kelvinator and carrier (which don't have a capacitor in the reciever circuit, and nothing stands out on the main PCB as the capacitor for the remote), you just have to change the main PCB.
I carry a soldering iron around and use it as much as I do my gauges these days. Fuji ducted with the solid state relay, stuff paying $100 for the PCB, the sharp relay is $16. Shorted diode bridge in a fuji? $6.
Breezair evap cooler not working, probably just the $8 TRIAC, stuff paying $400 for a whole new control system. ( A company called tekelec makes most of the PCBs for all different evap coolers here, try looking up www.tekelek.com.au they don't want to talk to anyone, too busy making control systems in europe and the USA to bother providing service here, and all the evap cooler maunfacturers keep selling "upgrades" of tekeleks inferior stuff to the new model, meaning huge expense for a simple PCB fault in an evap cooler, the PCBs seriously have like 4 components in them for fan speed control, and they charge $400 for a wall control or wireless remote control, prices that worldwide refrigeration split systems would be ashamed off. I wish I knew an electronics guru to take those PCBs to pieces and get rid of the tekelek scam.).
But anyway, what I'm saying is that even though I do stuff around changing components on PCBs, I've never got a carrier a/c which is not recieving the remote signal working buy changing the IR sensor or capacitors. Getting them to work without changing the main PCB is above my knowledge.
edit:
Also, heres a tip, buy a universal remote to carry around and test with, if it doesn't work with that, the main PCB needs replacing. The best/cheapest universal remote are from www.dealextreme.com
these ones http://www.dealextreme.com/details.dx/sku.14835 are US$7 (shipping is free but takes 3 weeks)and have louvre swing and backlight unlike the rest. Those remotes even work with the really old sliding switches in daikin/fuji a/cs out there, so I've bought heaps to sell to customers with really old gear they want to fix cheap.Last edited by paul_h; 12-03-2010 at 02:16 PM.
15-03-2010, 09:22 AM #20
Have you checked "flow switch"? If there is an issue with flow switch it is possible for water freezing. Except continiously flashing of RED light on the PCB do have any alarms on the PRO-Dialog?
24-03-2010, 07:10 PM #21
r u people talking of chillers or split units? its so confusing, 1 question at a time please
24-03-2010, 10:24 PM #22
31-03-2010, 07:42 AM #23
remember there can be dipswitch s where batteries r for remote control i think most carrier splits have this feature a and b dipswitch by memory sometimes when changing batteries etc this setting can be changed stopping signal getting to reciever on indoor unit more than likely though sounds like main pcb
31-03-2010, 10:27 AM #24
Advical,
If you follow the below link, it will take you to the service manual for this unit. The manual has a different model, but it is the same unit (they are re-model numbered overseas).
eto.carrier.com/litterature/Service_Manuals/AEM001E1.pdf
Remeber to put http in front. I am unable to do this, not enough posts.
Mat
Carrier Chillers
By Ed Burris in forum Technical DiscussionsReplies: 6Last Post: 27-03-2010, 02:00 AM -
Geoff in NY ~ Carrier Parts
By Futsal1st in forum Trouble ShootingReplies: 6Last Post: 30-12-2009, 04:07 AM -
Help identifying carrier HiWall dom. split
By paul_h in forum Air ConditioningReplies: 4Last Post: 12-12-2008, 09:12 AM -
carrier remote
By superswill in forum Trouble ShootingReplies: 2Last Post: 26-04-2006, 09:17 PM
