08-01-2010, 10:42 AM #1
Carrier xarios 300 running too cold
Im havins a problem with a carrier xarios 300. The operating temp is set for 3° the otside temp is -8° but the unit won't go above -4°.The unit has just been re-gassed, new drier and serviced at the beginning of December.
This is happening wether running on road comp or standby.
Please help
08-01-2010, 11:02 AM #2
Re: Carrier xarios 300 running too cold
or if possible could someone help me out with a manual
thanks
08-01-2010, 02:26 PM #3
08-01-2010, 10:50 PM #4
Hi Big Jim,
The processor is probably interpruting the low discharge pressure as low system charge and locking out system, try blocking off air to condenser coils and fooling the processor input information. A bit like those cover/curtain things in front of truck engine radiator for low outside temps.
magoo
09-01-2010, 02:00 AM #5
14-01-2010, 10:13 AM #6
Carrier Xarios systems in Australia are all cooling only. can't Imagine modern Carrier would have the imagination or drive to generate different designs for different countries.
14-01-2010, 12:56 PM #7
It's perfectly normal. The heat exchange and air entrainment are small, though enough to lower the temperature of the cell. If you want a higher trailer temperature then you need to find a way to heat it up from the inside.
Need Fault Codes For Carrier Xarios 500
By Chris2005 in forum TransportReplies: 6Last Post: 03-03-2011, 09:19 AM -
Carrier Xarios 500
By kenleung0607 in forum Refrigeration BooksReplies: 3Last Post: 31-07-2009, 03:04 AM -
Problems with compressor running too cold
By abrando1 in forum Trouble ShootingReplies: 8Last Post: 12-05-2009, 10:08 PM -
Carrier xarios 300
By imes in forum TransportReplies: 2Last Post: 12-12-2008, 07:29 PM
