Results 1 to 44 of 44
Thread: Mitsubishi Mr.Slim heat pump
Threaded View
02-01-2010, 02:56 AM #30
Re: Mitsubishi Mr.Slim heat pump
I'll give you the way to know for certain:
1. Open the outdoor unit - gain access to the compressor;
2. Install a temp sensor 150mm from the compressor exit, on the discharge line (the hot one);
3. Let the unit pull down & watch the discharge temp;
4. If temp exceeds 107-110'C, then you are pushing your unit too far.
It is possible that the manufacturer lets the compressor discharge run up a little higher on non-continuous load, but not too much higher.
Let us know how you get on.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
New Heat Pump Forum
By Argus in forum Heat PumpsReplies: 17Last Post: 10-04-2010, 09:12 AM -
Sizing of Heat pump
By pinkpanther in forum Tools and CalculatorsReplies: 5Last Post: 24-05-2009, 08:16 PM -
Homemade Heat Pump...
By AC_Hacker in forum New to REReplies: 0Last Post: 29-04-2009, 11:30 PM -
commisioning mitsubishi heat pump boilers?
By northcool in forum Air ConditioningReplies: 2Last Post: 22-09-2008, 08:28 PM -
Will this heat pump work?
By goodguy in forum Heat PumpsReplies: 7Last Post: 08-03-2008, 04:14 PM
