Results 1 to 10 of 10
Thread: Toshiba Twin Split
29-12-2009, 06:08 PM #1
Toshiba Twin Split
Just been given the order for the following;
1No. RAV-SP1404AT-E Super digital outdoor 14kw.
2No. RAV-SM802KRT-E High wall indoor 7kw.
Question is that I have been told by my supplier that the wall mounted twin systems do not come with a refnet joint as they have pmv's and I am just to just a standard refrigeration 'T' piece instead.
This to me just seems strange as I have always in the past used the 'Y' piece refnets with Daikin etc or is this the norm with this type of system??
Thanks in advance,
29-12-2009, 07:53 PM #2
Re: Toshiba Twin Split
If you want some manuals for these check out here...
http://www.cooldesignsltd.co.uk/toshiba-manuals.htm
One of them shows a tee piece in a mini-schematic but the other quotes Branch Pipe ref RBC-TWP30E-2/50E-2 so it seems that they do have something available.
edit: Just found this on the twin kit....
http://www.toshiba-aircon.co.uk/tech...n%20Manual.pdfBrian - Newton Abbot, Devon, UK
29-12-2009, 08:43 PM #3
get tees from your local wholesaler they work the same and much cheaper than from tosh
30-12-2009, 08:42 AM #4
Thanks for that.
Yes my suppliuer told me just to provide my own Tees from elsewhere.
Never bought these before. Are there different types or just plain standard tees? Also suitable for R410a? Will need 5/8 and 3/8''. Will HRP stock them as will order other bits from them.
30-12-2009, 03:16 PM #5
yeah standard tees will be fine just nitro braze and try to get the same amount of pipework each side of the tee i.e. 3m either side of the tee to the units
30-12-2009, 04:47 PM #6
30-12-2009, 06:30 PM #7
Just to repeat and confirm what all the others say, yes just use standard T's.
I have made the mistake of buying the genuine Tosh kit once, guess what turned up standard T's.
Eggs
31-12-2009, 10:13 AM #8
Yeah I remember reading ages ago on here about Mitsi using tees.
Eggs, the Tosh tee kit, do you not even get insulation for the joints?
Also the wiring of this as far as I gather is from master to slave 1,2 and earth (not 3 comms) connected and then from controller to master to slave is a and b daisy chained?? Anything else I need to do i.e dip switches?
Can this outdoor unit be disabled to cooling only??
Thanks,
31-12-2009, 12:04 PM #9
that is correct 1,2 and earth not 3. controller A and B to master then to slave no need to touch dip switches on splits they set there selfs up unlike there vrf's
26-01-2010, 09:07 PM #10
For future reference, the "Twin Kit" has STANDARD refrigeration tee's but also has electrical filters, one per indoor unit, the filters were originally required to meet CE markings.
Save money and use box standard tee's, the filters are no longer needed.
Have fun.
dip switches on hitachi twin split
By moondawn in forum Air ConditioningReplies: 3Last Post: 14-10-2009, 04:54 PM -
Toshiba split
By sexysouthwest in forum Air ConditioningReplies: 11Last Post: 25-06-2009, 06:25 PM -
Toshiba multi split runs non-stop
By expat in forum Air ConditioningReplies: 4Last Post: 30-10-2008, 09:25 AM -
Daikin twin split
By Lippygit in forum Trouble ShootingReplies: 2Last Post: 28-07-2007, 06:28 PM
