Results 1 to 2 of 2
10-11-2009, 07:06 PM #1
whirlpool side by side fridge/freezer
Ice maker not working suspect infared ice level sensor any way of testing sensor ? may be some body can help cheers
wacker.
04-12-2009, 05:32 AM #2
Re: whirlpool side by side fridge/freezer
Keep in mind I'm in the states, so I'm going off US appliances. In the grill of your refer there should be two tech sheets. One for the refer, one for the icemaker/optics. Generally when you open the freezer door the light should be blinking. Close the flapper door and the light should be solid. Common problem with in the door dispensers are the gears off the icemaker module breaking, and the fill tube freezing.
Good luck
By lamplighter2 in forum Trouble ShootingReplies: 0Last Post: 09-07-2009, 10:02 PM -
By paul_h in forum DomesticReplies: 5Last Post: 03-02-2009, 07:14 PM -
New Whirlpool Sideby Side 20RI D3
By StevenHarper in forum DomesticReplies: 6Last Post: 20-12-2007, 01:02 AM -
Whirlpool side by side - Freezer intermittent fault
By Chouman in forum Trouble ShootingReplies: 14Last Post: 17-11-2006, 10:34 PM -
Ice Box on my Whirlpool Fridge/Freezer not working
By Chouman in forum Trouble ShootingReplies: 5Last Post: 18-09-2006, 01:23 AM
