Results 1 to 50 of 50
    Mar 2002
    Spain
    67
    R507 instead R404a?
    I´ve heard that R507 is a better refrigerant than R404a, and it is going to substitute R404a because R507 was patented some years ago?
    Some comments...?
    Sep 2003
    ISRAEL
    72
    4,248
    Re: R507 instead R404a?
    Just between the two of us, when ever any unit works on 507 brakes, I change it back to 22.
    From that moment it works better.
    No, I didnt hear such a thing.
    Chemi
    Apr 2001
    79
    5,071
    35
    The two refrigerants are almost identical. Essentially, if you take R507 and add a small amount of R134a, it becomes R404A.
    Sep 2003
    ISRAEL
    72
    4,248
    Hi Gary,
    True but 507 has a slight higher pressure on condensing,
    still they are not as good as 22.
    Chemi
    Oct 2004
    Australia
    64
    I agree with gary they are all most identical even the price is almost the same. I disagree with R22 being better. There also about the only refrigerants that are ok to mix in a system. I have always disliked R22 especially in low temp applications.Having to run head cooling fans and on s'market rack systems desuperheating TX valves on the suction header. On medium temp care must be taken to ensure low superheat or discharge temps go off thier face. I still think R22 is still for air conditioning. R404a and R507 are long term replacements for good old R502 with the use of POE oil. Regards Kev
    Sep 2003
    ISRAEL
    72
    4,248
    Hi Kev,
    I use 22 for years for AC and low temp down to -18 freezers.
    No problems at all, no head cooling fans (its hot over here)
    In new freezers, I have sterted to use R404.
    Chemi
    Apr 2001
    79
    5,071
    35
    Hmmmmm...
    R134a is not a blend, and therefore cannot separate.
    IIRC, R507 is a near azeotrope. Adding a little R134a to it, making it R404A makes it a zeoptropic blend, thus the R134a can separate where there is a saturated mixture, but will blend back together everywhere else in the system. Fractionation inside the system is not a problem.
    As I understand it, the biggest problem with the new refrigerants is POE oil. It is not only hydroscopic, but highly detergent as well.
    I don't know anything about the world bank, nor do I care, but the ozone depletion farce was pure BS, and I will never forgive the EnviroNazis for screwing up my industry. They took the joy out of my job. The only group that makes me more angry is the TobaccoNazis.
    Sep 2003
    ISRAEL
    72
    4,248
    Funny Gary but I know exactly how do you feel
    Chemi
    Oct 2004
    Australia
    64
    Gary i agree the ozone buisness is a crook off s h i t . Didnt it come at the same time as duponts patents on ***** run out? And as i understand it dupont was the main company backing the ozone theory or am i just suspicious?
    shogun7's Avatar
    shogun7 Guest
    Has anyone used Icors NU-22
    NU-22 is the most practical and natural choice for the replacement of HCFC-22. It is the only HFC based R-22 replacement that is compatible with synthetic and mineral oils (MO,AB,POE). NU-22 has also proven to be compatible with all standard equipment components and materials used in R-22 manufactured systems. After conducting over one thousand hours of compressor wear testing, NU-22 has proven to be fully suitable for use in scroll, screw, rotary and reciprocating compressors.
    Feb 2001
    Doncaster, England
    199
    Thumbs up Re: R507 instead R404a?
    R507 is an azeotrope (not a near azeotrope).
    All R500 numbers are azeotropes.
    Tony
    5,667
    Can't say I've heard of it Shogun
    Is it available in the UK or just Stateside?
    shogun7's Avatar
    shogun7 Guest
    Quote Originally Posted by frank
    Frank, I believe it's only avialible in the US and Canada...you can read more about it at:
    http://www.tropicsupply.com/RefrigerantsicorNU22.htm
    ireland
    1,450
    Frank
    Its available from klea as AZ50.
    Apr 2001
    2,099
    27
    I don't know anything about the world bank, nor do I care, but the ozone depletion farce was pure BS, and I will never forgive the EnviroNazis for screwing up my industry. Gary
    I said this many times before.............Next time some bald headed, bearded, , white coated , university lab closetted scientest, comes up eith a theory and blurts out,
    " the temp of the world is rising.................The ice caps are melting........... We BLAME CHLORINE..................Lets go look for chlorine........."
    They found it, it was a constituent of refrigerants...........or solvents as they were fond of calling it.
    Who was blasting tonnes of the stuff every day..............Yes , mainly R11 as a cleaner.
    The Tobacco companies used it to " fluff" up the tobacco, blasted hundreds of tonnes into atmosphere every day
    The Pcb , chip electronic manufacturing companies. To clean electronic components. ( Silicon Valley)
    Aerosal companies who filled cannistors with it.
    Like with all other issues, they could have stopped these industries using refrigerants............
    No , they developed a whole new host of refrigerants
    We , refrigerant people had no voice...........we sat back glumly and took it on the chin...................
    It says a lot about us.............
    Look at the hunting ban here..............Do the Country Alliance sit back ??? No they dont..............They fight back for what they see as their right to kill poor little fox.
    I by the way do not agree with killing animals for sport, wether it is a fox in an english meadow, or a Rich Yank paying his green dollar to down a magnificent lion..............or giraffe..
    They is always a solution to things..............Solutions are destroyed when money aspects override the issues.
    The chemical companies saw an opportunity to make big money.........
    Who said it was Dupont ?? who supported the idea..........If is is true we can start by stop buying dupont refrigerants.......
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    Mar 2003
    Tanzania(East Africa)
    59
    27
    I did try and found out R507 works better then R404a
    Sep 2003
    ISRAEL
    72
    4,248
    Hi Jay,
    Good to see you here.
    Better in what? AC or refrigeration med, or low temp?
    Chemi
    Mar 2002
    San Francisco Bay Area
    180
    Quote Originally Posted by Aiyub
    Actually, chlorine was fingered for the ozone hole, not global warming.
    Perhaps the hole is a naturally occurring phenomenon, but the truth is we were pumping billions of tons of crap into our atmosphere. I was skeptical of the science until I read a pretty understandable paper which convinced me it was too probable to ignore.
    Pollution is one of the things we humans do best. Denying that we are poisoning ourselves is probably the second. Look at all the epidemics in all the cities of the world before sanitation. We used to dump our sewage in the streets, let it run into the rivers. Downstream cities drank it.
    I think it says we care more about the health of the planet than our own convenience.
    Another word for it is self-interest. We all have a hard time seeing beyond our own. It's why our world is the way it is. We live in an amazing paradise: incredibly beautiful in every way, food grows from the earth itself or falls from the trees. But we only see the worm in the apple or decide we don't have enough.
    And then orchestrated an international conspiracy in which they enrolled scientists from around the world to create a bizarre theory? And not a single conspirator blew the whistle, and they all either did it for no personal gain or else the secret payments from the chemical companies were never discovered?
    Hmmm. I either need more details of this amazing conspiracy or send me some of that stuff you're smoking, Dude!
    Relax. Life is short and most of it can be pretty good if you can get your attention off whatever it is you love to bitch about!
    Rog
    Apr 2001
    2,099
    27
    Quote Originally Posted by RogGoetsch
    Rog
    Dont be so daft and condesending Rog..............use your bottle
    You dont need to " muster" opr mobilise a coalition or alliance in order to "conspire"
    You need an army of sheep..........
    Youre a typical American.........
    Mar 2002
    180
    Sorry if I sound condescending, Abe. I come from a country where the President can't get a blow job from an intern without the entire world knowing about it! Conspiracy theories don't hold much water with me. Like Occam's Razor, the simplest explanation is probably the most correct.
    I think the industry might have done more to oppose the change except that everyone above the tech level saw the profit potential in the change, and only the techs feel the pain.
    Rog
    Sep 2003
    ISRAEL
    72
    4,248
    Hi Rog,
    Its not only the techs pain, its the simple problem that no one was able to bring any proof so far!
    Al we've heard in the past ten years was, bla, bla, bla.
    But try to to find the bank balance of Dupont for example,
    I'm sure you will see a sharp curve upwards of the income, baseb on what we call over here, Got the customers by the balls.
    Can any one afford not to pay the price?
    I'm only making money out of it but I feel i'm cheating on my clients
    Chemi
    Apr 2001
    2,099
    27
    Rog
    Hey Rog,
    I blurted out my response this am...........but glad to receive a response from you.........Now lets get this straight.........
    Who said anything about a conspiracy ????? Did I say it ????
    Or did you make it up..........or go on the defensive.........as you guys are prone to do.........
    What Im referring to is the way Big Business operates...............anywhere in the world.
    Businesses need to launch new products , new models, new technologies............new software..........incorporate a few changes, jazz things up, in most cases we do benefit from better more efficient products..........
    So , tis no conspiracy...........tis business. Thats the way of the world.
    I did slip up on the global warming ...............it was that darn hole in the sky and people fearing about getting more skin cancers.......... Thanks for pointing it out.
    But you ignore my argument about Industry who vented hundreds of thousands of cfc's into atmosphere............Not fridge techs.......
    A better solution would have been to analyse usage..........bring in controls, licensing and methods..........yes, recycling and all that crap..........
    Not wholesale elimination............
    Hence, my prognosis that it was engineered by big business for monetary gain................and that is my view...........everybody can make their own minds up.......and I will encompass all views or opinions............
    And I promise..............I wont accuse you of being high on dope if your opinion differs from me..........
    Since you guys are so concerned about environments.............how about your lobbying your legislator to sign up to Kyoto!!!
    Adieu Bud...........Have a great day...............
    Abe
  23. #23
    Dec 2004
    Romania
    59
    66
    HY.
    I Prefer R 507 because, I ask you what hapen*t when you lose 20% of a charge R 404 a . Is the same when you lose 20%
    of R 507.what* s your opinion.
  24. #24
    Apr 2001
    2,099
    27
    Occams Razor
    Occams Razor
    Occam's Razor (also Ockham's Razor or any of several other spellings), is a principle attributed to the 14th century English logician and Franciscan friar, William of Ockham that forms the basis of methodological reductionism, also called the principle of parsimony.
    In its simplest form, Occam's Razor states that one should not make more assumptions than needed. When multiple explanations are available for a phenomenon, the simplest version is preferred. A charred tree on the ground could be caused by a landing alien ship or a lightning strike. According to Occam's Razor, the lightning strike is the preferred explanation as it requires the fewest assumptions.
    http://en.wikipedia.org/wiki/Occam's_Razor
    I picked up the definition from link above.
    Marc, are there no limits to your knowledge and brilliance ????
  25. #25
    Mar 2002
    180
    Quote Originally Posted by Marc O'Brien
    You mean that the hole might be natural is likely more correct?
    Ooooh, good one, Marc! Could very well be.
    Rog
  26. #26
    Mar 2002
    180
    Yeah, and you know what we do when we get defensive! Besides, I’ve heard you guys have WMD’s (Weapons of Mass Destruction), so watch it!
    Abe, conspiracy just means two or more agreeing, usually in secret, to do something, usually wrong. For business to “engineer” the change would mean more than one person agreeing to make it happen. That’s all a conspiracy is.
    Your solution makes too much sense to actually be agreed to by any governing body I’ve ever heard of. I think it was only fear that motivated the world community to come together on this, and fear, while an effective motivator, does not care for fine distinctions.
    Perhaps we could have made an exception for refrigeration use, but in one discussion I read in the early days of the debate, it was generally accepted that most refrigerant would eventually leak out, no matter how good the regulations and practices, since that’s what old systems do.
    Besides, everyone thinks his use is critical and should be the exception. Emotionally we’re still children. “If I can’t have it then neither can you.”
    Please. Here in California we refer to it as “medical marijuana” and everyone has some in his medicine cabinet. As a matter of fact, I think my back is going to feel sore in a little while….
    What?! And offend our biggest polluters…er, ah, I mean political contributors… no, wait, I mean industries? We’ve got the best democracy money can buy and as long as it stays bought, we don’t have to worry about little things like breathing or getting along with the rest of the world. And global warming concerns are for people without air conditioning!
    Rog
  27. #27
    Mar 2002
    180
    Quote Originally Posted by chemi-cool
    Chemi:
    (Ozone depletion by chlorine is a theory, hence not provable, but possibly disprovable. Theories explain observable phenomena and allow us to make predictions. If a prediction fails, then the theory needs to be revised or discarded.)
    Chemi
    I understand your frustration. I, too, frequently feel embarrassed when I hand the customer the bill. The refrigerant prices are outrageous, yet I still feel I have to mark up 50% to cover warranty if it leaks. How much mark-up do you use?
    Rog
  28. #28
    Apr 2001
    2,099
    27
    Rog
    So at the end of it.............You back track and end up agreeing to everything I said...............So your argument was a total waste of
    Y(our) time............
    Sheesssh............whats the point ?????
    In future Ill try avoiding talking to brick walls........
  29. #29
    Dec 2004
    8
    [QUOTE=RogGoetsch]Chemi:
    Theory? more like fact mate. you never study chemisty? when you mix CFC's with O3, the chlorine in them strips away O1 molecules from the O3 one atom at a time. hence ozone depletion. unless you can prove me wrong?
  30. #30
    Sep 2003
    ISRAEL
    72
    4,248
    So guys, it looks we will argue about the demage of refrigerants for many years to come or to be more presice, untill a new generation of techs, born after 1993 ( they are 11 now) wiil take the lead and r-12,22,502 will only be part of our history.
    So, wise guy, how much R-12 realesed in london, you will need to create a hole 1 sq/m over New-Zealand???
    But this is not the issue, it is the global worming.
    And there, the only factor is MONEY!
    I’ve heard you guys have WMD’s,
    Please Rog, for those who did not speak English at birth, explane WMD.
    Chemi
  31. #31
    Sep 2003
    ISRAEL
    72
    4,248
    So guys, it looks we will argue about the damage of refrigerants for many years to come or to be more precise, until a new generation of techs, born after 1993 ( they are 11 now) Will take the lead and r-12,22,502 will only be part of our history.
    So, wise guy, how much R-12 released in London, you will need to create a hole 1 sq/m over New-Zealand???
    Please Rog, for those who did not speak English at birth, explain WMD.
    Chemi
  32. #32
    Sep 2003
    ISRAEL
    72
    4,248
    Thanks Marc.
    Chemi
  33. #33
    Mar 2002
    180
    Rog
    Not really. I think we had to go ahead with the chlorine elimination as the safest approach given the data available and the slim chance of a consensus around any alternative.
    I also think it is a colossal waste of time and energy to bitch about it.
    Rog
  34. #34
    Mar 2002
    180
    Quote Originally Posted by Thom101
    The theory part is that this observable chemical behavior is occurring at high altitude with chlorine stripped from refrigerant molecules that are themselves quite a bit (4X?) denser than air molecules (O2 & N2); and that the hole we observe occurring without historical measurements to compare with, is not a naturally occurring phenomenon, but the result of this chemistry.
    Rog
  35. #35
    Mar 2002
    180
    Chemi
    Sorry, I must be overmedicating again!
    After this election, WMD has become a mantra over here. “Weapons of Mass Destruction,” also known as “Weapons of Mass Distraction” to those of us who think our leadership may be not wanting us to look at their whole record.
    WMD is stuff Britain and Europe have to assure themselves that the USA can never attack them. The USA would never attack a ligitimate force, they only ever take on straw men, country's that they know don't have WMD even if WMD is used as an excuse for attack
    Yeah, well don’t be too sure! Remember we can still muster a powerful coalition including umm, er, any country who will even talk to us in a few years!
    Rog
  36. #36
    Dec 2009
    United States
    47
    11
    Hmmmmm...
    so do you also hate the feminazis?
  37. #37
    Apr 2001
    79
    5,071
    35
    Quote Originally Posted by jsugalski View Post
    Yep... and just so you don't get the wrong impression, I don't like the conservatives, either.
    The thieves and dictators versus the dictators and thieves. Politicians are the scum of the Earth.
  38. #38
    Dec 2009
    United States
    47
    11
    fair enough, just the "nazis" part of your phrases prompted me to ask even if in jest...anyway I'll leave the politics for another time, that problem I had with the phase change unit in another thread, I do have a relevant bit to ask in this thread, I was considering getting a danfoss compressor to replace it on ebay, especially if it goes for as little as it is currently going for...it's a SC12CL R404A/R507 whereas the one I have in the unit is the stock nf9fx danfoss that is in it that I suspect has issues...I may have it fixed anyway, but the sc12cl uses better coolant either 404 or 507 depending on if this person refilled it vs the 134a in my current unit, as well as a slightly bigger motor so I should get better temps overall...just wondering what your opinion is on this.
  39. #39
    Dec 2009
    United States
    47
    11
    so in this case, it's not 507 vs 404, it's 134a vs 507/404 lol
  40. #40
    asproegypt1's Avatar
    asproegypt1 Guest
    I was searching for anything to re-charge my R-123a So I found Something Maybe It Will Be More Useful For Your Issue And
    otherwise it helps me too
    rizkbrothers.com/Arabic/products.php?tn=cHJvX3Byb2R1Y3Rz&for=Mzk%3D&main=0&sub=0&pro=39&lan=Ar
  41. #41
    muddassarusa's Avatar
    muddassarusa Guest
    Smile Re: R507 instead R404a?
    Hi Gary,
    what % can be mix with R-507 and R134a become correctly as R-404a? 10% or 20% or???
  42. #42
    Jan 2010
    house
    please correct me if i'm wrong,
    r507 and r404 is better for low temp applications than r22, my experience with r22 especially in our hot tropical climates is that the compressors bruns out faster than r404a/507 compressors,
    but 1 thing why i like r507 more than r404a is when you have a leak, r507, you can just refill the syatem after fixing the leak while r404a, you will have to drain all refrigerants and refill it because if youjust add it, the blend will not be perfect anymore for r404a....
  43. #43
    Jul 2008
    Quote Originally Posted by muddassarusa View Post
    Hi Gary,
    R404a
    44% of R125
    4% of R134A
    52% of R143A
    R507
    50% of R124
    50% of R143A
  44. #44
    Jul 2009
    Brisbane
    67
    79
    On low temp R507 is better than R404a. It is considered azeotropic because it has a temperature glide less than one degree. Tests done on partially replacing the R404a system charge at various percentages with R507 show little or no decrease in efficiency and in some cases an increase. R507 can be vapour charged which can be an added advantage.R22 is not as good at low temp especially on systems with higher than normal return suction temps due too high discharge temperatures. R134a is the best option for medium temp refrigeration and R22 will soon be phased out in many countries that havent done so already. I agree with you on R507 Gary but strongly disagree on Tobacco. As an asthma sufferer whos Asthma is triggered by cigarette smoke, I dont believe that smokers have a right to give me an asthma attack.
  45. #45
    Apr 2001
    79
    5,071
    35
    Quote Originally Posted by oldesky View Post
    It might interest you to know that I was an early advocate of non-smoker's rights. But somewhere along the way I realized that there was no quid pro quo, that non-smokers didn't give a damn about smoker's rights.
    If non-smokers don't care about my rights, then why should I care about theirs? If they think it's okay to rob me, then why shouldn't I blow smoke in their faces and watch them choke? Seems fair to me. I'm choking on their taxes.
  46. #46
    Feb 2009
    Australia
    272
    Interesting comparisions link below.
    www.solvay-fluor.com/.../r507_in_comparison_to_r404a_and_practical_experiences.pdf -
  47. #47
    Jul 2009
    Brisbane
    67
    79
    Gary whilst I greatly respect your refrigeration opinion, I disagree with you on tobacco. In saying that I do agree that you have a right to commit suicide as quickly or as slowly as you wish,as long as you dont kill or injure others on your quest.but this is a refrigeration site so I will not continue a fruitless and pointless argument.
  48. #48
    Jul 2007
    Australia
    1,845
    ^ you just did
  49. #49
    skoerper's Avatar
    skoerper Guest
    Have you tried R407A?
    It's a proven replacement in exsiting R22 low and med temp refrigeration equipment. No equipment changes or mods. Does require at least 50% POE.
    Copeland, Carlyle and Bitzer approved.
    Walmart, Food Lion, Costco, and many others are using it in new equipment since it has a low GWP compared to R507 and R404a.
  50. #50
    Horoaffonee's Avatar
    Horoaffonee Guest
    R507 instead R404a
    I would like to know if i can use the Microchip 25lc320 instead of the Atmel AT25320the datasheet looks like similary.Or maybe is there a equivalent by Microchipthank you
  1. R507 in an R134a compressor: any danger?
    Last Post: 21-12-2009, 12:44 AM
  2. capillary sizing for R404a
    By ding in forum Technical Speculations
    Last Post: 19-03-2008, 07:27 PM
  3. piping selection for R404A
    By drk_in in forum Tools and Calculators
    Last Post: 14-11-2005, 06:33 AM
  4. R507 in an R134a compressor: system design
    Last Post: 01-05-2003, 09:25 AM
  5. Replies: 2
    Last Post: 18-09-2001, 05:15 PM
