    Oct 2004
    U.K.-London
    144
    Isothermic humidifier
    How do I calculate the rate of evaporation of a steam humidifier?
    Never underestimate anybody, you never know when they will make you look like an idiot!
    11,024
    Re: Isothermic humidifier
    My first answer would be to read the instruction manual and the second would be to contact the manufacturer.
    Or, you could monitor the water usage and go from there...or measure the up and down stream air conditions...
    Oct 2004
    U.K.-London
    144
    Quote Originally Posted by Brian_UK
    Good idea, but this for a college assignment. I waswodering if there was a formula?
    11,024
    http://van.hep.uiuc.edu/van/qa/secti...nd_Condensing/
    Coolie, have a look at this, it may be of use to you or you may wish you hadn't started !
    Mar 2002
    San Francisco Bay Area
    180
    23
    Quote Originally Posted by Coolie
    What data were you given? Heat or power input?
    Rog
    Oct 2004
    U.K.-London
    144
    Will reply when I get home, where the info is.
    Thanks for the interest.
    Oct 2003
    5,630
    34
    The amount of steam depends solely on the heat you add to the water. This is a pure simple thermodynamical question.
    Adding heat to let it boil and then adding further heat to vaporise the water.
  1. humidifier selection
    By Krups in forum Air Conditioning
    Last Post: 14-05-2004, 08:52 PM
  2. Humidity
    By frank in forum Air Conditioning
    Last Post: 30-12-2002, 08:06 PM
