Results 1 to 1 of 1
02-11-2009, 07:40 AM #1
Problem in Thermax chiller machine
We have one 1150 TR single effect steam fired chilling unit.Since last month it is not performing well. The refrigerant level has increased but we did not notice any reduction in absorbent level.Even we are not able to blow down the refrigerant.Vacuum level is 17 mm HG.in shell and 20 in storage tank.One peculiar thing observed that when we stop the machine,The refrigerant level goes a bit high and after 20 minutes of dilution cycle when absorbent pump stops the level of refrigerant again increases and goes above the evaporator sight glass.
Problem with mcquay chiller
By texanul in forum IndustrialReplies: 6Last Post: 04-02-2010, 08:51 PM -
York Chiller High Line Voltage Problem
By shamyl in forum ElectricalReplies: 5Last Post: 19-07-2009, 07:53 PM -
Chiller connectivity problem
By ALLAHHOOPK in forum New TechnologiesReplies: 2Last Post: 12-05-2009, 05:57 PM -
york chiller motor rotation error
By cesarnino in forum Trouble ShootingReplies: 7Last Post: 13-12-2008, 03:43 PM -
neslab chiller water pump problem
By bill0577 in forum Trouble ShootingReplies: 5Last Post: 19-10-2006, 05:22 PM
