Thread: Amcor mini split control board
18-10-2009, 02:21 AM #1
I hope someone here can help me. I have a 6 moth old Amcor mini split ac (AOS091HX). Two months after buying it and having it installed, the outside control fried itself somehow. I've been waiting 4 months for a replacement control board only to now find out the Amcoraire is out of business. Their website is gone and all the #'s are disconnected.
Can someone either point the way to where I can get another control board? Or perhaps a control board from another brand? I'm really in a bind and I don't have the $$$ to buy a another complete unit.
Thanks in advanced.
19-10-2009, 05:47 PM #2
Re: Amcor mini split control board
Paul
"KEEP IT COOL"
25-10-2009, 01:06 AM #3
the amcor HX series units are manufactured by Chigo-group... they are pretty much identical to the Grunaire HX series units... in fact the outdoor units are identical... indoors the only difference are the display boards that connect to the indoor board... you should be able to get a board for the Grunaire 9,000 BTU HX unit and be Ok... Turbo-air;s TAS series units are also like these amcor units...
I doubt anyone will honor the warranty unless perhaps you could say the board came out of a Grunaire unit.. or contact Chigogroup in china directly and explain your situation that amcor-aire is gone...
-Christopher
Split board consumer unit
By Swipe in forum Air ConditioningReplies: 34Last Post: 07-05-2009, 07:11 PM -
Lost Remote Control for Split System AC
By kiamaian in forum Air ConditioningReplies: 5Last Post: 12-04-2009, 06:12 PM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM -
Trane Defrost Control Board Energize "W" in cooling
By jcmorris2 in forum Heat PumpsReplies: 6Last Post: 02-06-2007, 03:40 AM -
Circut on a main power split board ?
By fridg in forum ElectricalReplies: 13Last Post: 12-03-2006, 07:56 AM
