Results 1 to 8 of 8
Thread: Q about evaporator
01-11-2004, 01:13 PM #1
Q about evaporator
Hi 2 all!
If I choose an evaporator (dry expansion) and get surface reserve 50%. Is the value of surface reserve good or critical and very bad?
BR
Andrew
01-11-2004, 08:31 PM #2
Re: Q about evaporator
Hi Andrew
Do you have any other ways of asking?
01-11-2004, 09:53 PM #3
is it reserve as in "area" maybe
nature reserve (area)
wildlife reserve(area)
just my initial thought.
cheers
eggs
02-11-2004, 04:10 AM #4
[QUOTE=Andrew Pribora]Hi 2 all!
If by surface reserve you mean that the evaporator will be greater capacity then the condenser then I would suggest to you not to do it because a mismatched system will result in a drop in efficiency, in addition, if one coil is changed and its replacement is either smaller or larger than the remaining coil, the charge and expansion device may need to be adjusted in order to keep from flooding or starving the coil. In severe cases, a lack of superheat results in floodback to the compressor, which can cause compressor failure and coils that are not optimized will not remove the amount of moisture they should, therefore sacrificing comfort as well as efficiency.
02-11-2004, 11:53 AM #5
I mean by "surface reserve" - greater capacity of ev.
But I don't agree with necessivity of matching "evaporator-condenser" - we use mulltiset and in such case it is not important.
My opinion - it is not critical (in reasonable limits!).
02-11-2004, 04:38 PM #6
The evaporator TD is the difference between the refrigerated space temperature and the temperature at which the refrigerant is evaporating (saturated suction temperature aka SST).
Enlarging the evaporator coil reduces the TD by raising the saturated suction temperature (SST).
The coil outlet superheat cannot exceed the TD, because the TEV sensing bulb, which is contained within the refrigerated space, can be no higher than the refrigerated space temperature.
Given the higher SST and low sensing bulb temperature, the TEV cannot be adjusted properly, because the TD is insufficient.Last edited by Gary; 02-11-2004 at 04:44 PM.
03-11-2004, 07:00 AM #7
Originally Posted by Andrew Pribora
But what is "mulltiset"?
Rog
03-11-2004, 09:44 PM #8
A central pack with several evaporators.
copper evaporator
By nic0 in forum Technical DiscussionsReplies: 24Last Post: 26-08-2011, 11:24 PM -
Designing Roll Bond Evaporator
By Munzar Ata in forum FundamentalsReplies: 11Last Post: 05-08-2010, 11:31 AM -
Air Source Heat Pump - temp of refrigerant leaving evaporator
By anup in forum FundamentalsReplies: 3Last Post: 06-11-2006, 05:04 AM -
Change evaporator
By tralex in forum FundamentalsReplies: 6Last Post: 29-12-2005, 07:53 PM -
Iced Evaporator
By Abe in forum CommercialReplies: 13Last Post: 06-11-2002, 01:34 PM
