Thread: Max ppm water Max TAN/AN
06-10-2009, 03:16 AM #1
We need help with the max ppm water and max/change in TAN for stability in a set of turbine compressors on a reactor cooling system.
The units are Carrier chillers and operate on Hydrofluorocarbon (HFC) R 134a
Each chiller has a nominal charge of approximately 748 Kg per chiller.
OIL MANUFACTURER: CASTROL
OIL TYPE: ICEMATIC SW
PPM water is @ 69 ppm on one unit and although this level appears OK should this be lower?
TAN at present is 0.1 but we have no trends and again this seems reasonble but we have not checked new oil for a base line.
Any assistance or info we can get will be appreciated.
This is a continuation of our previous post on this subject
Thanks for the info
regards
Rob S
06-10-2009, 08:49 PM #2
Re: Max ppm water Max TAN/AN
why not mail Carrier and ask them for exact data ?from my knowledge your TAN is ok as for the water we use % not ppm so i cant say!
are these units screw ?or centrifugal?
06-10-2009, 09:02 PM #3
Which model chillers are they, perhaps we can find the data also.
Hoshizaki Ice Maker
By Abe in forum Legal-Business-MarketingReplies: 19Last Post: 01-05-2010, 03:27 AM -
Fact or Fiction
By david.findlay in forum FundamentalsReplies: 40Last Post: 09-03-2009, 06:19 PM -
cold river water
By eftimios in forum FundamentalsReplies: 8Last Post: 09-11-2008, 06:37 PM -
Modifying aricond. for heating, cooling and hot water
By kimusabi in forum Technical DiscussionsReplies: 3Last Post: 10-10-2008, 07:28 AM -
open cycle R718 A/C that also provides high purity water?
By star882 in forum Technical SpeculationsReplies: 7Last Post: 27-07-2006, 04:18 AM
