Thread: Oli Return System
30-09-2004, 11:44 AM #1
Oli Return System
Hi To All!
Question: in multicompr. racks must be oil return system.
I understand there are:
- on low-pressure side
- on high-pressure side
also can be:
- with electronic control (or with moving parts)
- without moving parts
Do you know firm-suppliers/producers such system?
BR
Andrew
Moscow/Russia
30-09-2004, 01:02 PM #2
Re: Oli Return System
The Alco "Traxoil" system is good. It bolts onto the compressors and controls the level in the crankcase, can be used on LP or HP systems.
Hope this helps
30-09-2004, 10:39 PM #3
There is always Henry Valves I think.
01-10-2004, 07:22 AM #4
Thanks!
ALCO, Henry.
What about Linde-System? It is a German Firm (now a part of Carrier).
02-10-2004, 09:21 AM #5
Have a look
http://www.esk-schultze.de/oil_control_system.pdf
http://www.henrytech.com/products_acr.html
Best regards.MarkLast edited by Mark; 02-10-2004 at 09:26 AM.
11-10-2004, 04:03 AM #6
Trax On Oil return Systems are standard devices installed in Supermarket Installations to regultate oil return.
They are proven to be reliable and have a good track record.
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
System Burn Out Troubleshooting
By altaf22m in forum Technical DiscussionsReplies: 13Last Post: 07-05-2010, 09:24 AM -
Burn out System, Clean up procedure. & Troubleshooting.
By altaf22m in forum CommercialReplies: 19Last Post: 15-04-2008, 07:03 PM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM -
Automotive A/C Vent Temp Range vs System
By Don Browney in forum Air ConditioningReplies: 1Last Post: 15-05-2002, 06:19 AM
