Thread: Climaveneta WRAT SL 1804 Problem
25-08-2009, 05:26 PM #1
Hi all, just attended a Climaveneta WRAT SL 1804 with CVM 3000c controller and CT 3 showing E103 fault - compressor thermal overload protection, checked over load and thermistor and both appear to be ok. I have no electrical drawings for this unit so a bit stuck with where else this particular control circuit goes, does it go straight back to the PCB as an input, if so where?
Any help would be great or a drawing.
cheers
26-08-2009, 05:20 AM #2
Re: Climaveneta WRAT SL 1804 Problem
hi:
in most thermal o.l u have to reset the control power to the thermal overload unit for a moment see if this helps
if u want the manual i will be happy to send it
26-08-2009, 07:26 PM #3
Cant reset the controller, is there a special technique, fault LED stays on for Comp 3, tried power reset, tested thermistor, electrical overloads, if the manual can shed any light then please send on, by the way i have the manual for the controller but not the chiller.
cheers
26-08-2009, 08:00 PM #4
Turn off then on the main switch on the chiller.
27-08-2009, 09:41 PM #5
29-07-2010, 07:11 AM #6
it goes in and out of the pc no more things in line
MFI AMP6855 defrost problem
By gliderpilot47 in forum DomesticReplies: 4Last Post: 12-01-2011, 12:11 PM -
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 04:00 PM -
Saunier Duval Problem
By mallorcanangel in forum Air ConditioningReplies: 1Last Post: 10-07-2009, 01:26 AM -
IMI Marstair HLR 540 problem
By markj in forum Air ConditioningReplies: 9Last Post: 01-07-2009, 11:07 PM -
Furance problem
By ALONEI in forum Trouble ShootingReplies: 10Last Post: 14-05-2008, 11:32 AM
