21-08-2009, 05:56 AM #1
Rotary Compressor Failure Reasons
Dear All,
Can somebody help me in getting the Rotary compressor failure raesons in Residential split air conditioners.I would be grateful.
Waqas
21-08-2009, 06:22 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Rotary Compressor Failure Reasons
Overcharging (liquid hammer)
Refrigerant leak (overheating)
Restriction in refrigerant flow (overheating)
Faulty condenser (failure to start, overheating)
Faulty overload relay (overheating)
Faulty 4-way valve (overheating)
Bad power supply (failure to start, overheating)
Damaged wiring (failure to start, overheating)Last edited by nike123; 21-08-2009 at 06:46 AM.
21-08-2009, 09:39 AM #3
Compressor's failure is a result of many causes. It could be a mechanical failure or an electrical failure.but before we answer the question we must know how it was performing before the failure occured .once we know that we will be able to get the correct answer to the question
22-08-2009, 08:50 AM #4
poor istallation
no evacuating
using water pipe instaed of refrigeration pipe
leaks due to using plumbing flares
these are what i have seen
Rotary compressor a good choice in VRF?
By K.R.Iyer in forum New TechnologiesReplies: 3Last Post: 04-06-2009, 06:08 PM -
piston type vs rotary
By friocold2008 in forum Air ConditioningReplies: 2Last Post: 28-05-2009, 08:38 AM -
Dehumidifiers and Rotary Compressors
By Pete L in forum CommercialReplies: 3Last Post: 16-10-2007, 11:06 PM -
Reasons for High Pressure / Low Pressure Trip outs
By majikman in forum Air ConditioningReplies: 19Last Post: 02-02-2007, 08:47 PM -
Bearing trouble - rotary compressor
By rosetennis in forum Industrial CompressorsReplies: 6Last Post: 18-05-2006, 01:26 AM
