18-08-2009, 04:45 PM #1
CAREL equavalent of T775M2006 (Honeywell)
Hi Guys.. I am new in this controller thingy. Anybody know what is the equavalent model from Carel for T775M2006 (Honeywell)?
The Honeywell controller is faulty and we have plan to replace it. Trying to source for other options...
18-08-2009, 11:37 PM #2
Re: CAREL equavalent of T775M2006 (Honeywell)
Best to ask Carel for their options, that Honeywell unit looks a bit special.
http://customer.honeywell.com/honeyw...tSpecificationBrian - Newton Abbot, Devon, UK
19-08-2009, 04:57 AM #3
ya... it looks special and complicated. Will try to contact Carel to look for equavalent function
19-08-2009, 09:24 AM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Here is another company which could have what you ask for.
20-10-2009, 12:24 AM #5
could you explain what the function of the controller is for.
as far as i con see from the manual you only have
2 modulating outputs 2-10VDC or 4-20mA,
no relay outputs
2 sensor input, honeywell 1097 Ohms PTC at 77° F (25° C)
if it is something simpel you could use the new
johnson controls system 450 series
25-10-2009, 02:34 PM #6
Hello KAKA,
i can recommend for you which Carel model for you replacement.
can you tell me more or PM me for info.
eg. application, no. of comp. or output.......
i do keep stock for 1,2,4 & 5 stage controller...
w.l.ong
carel controller hidden reset button
By 123-steve909 in forum CommercialReplies: 1Last Post: 01-06-2009, 09:54 PM -
Carel temperature controller issues
By tegwin in forum ElectricalReplies: 10Last Post: 30-01-2008, 03:10 PM -
Honeywell chilled water temperature controller
By Cofreth in forum Technical DiscussionsReplies: 4Last Post: 07-09-2007, 06:32 PM
