Thread: Mitsubishi electric fault code
14-08-2009, 07:35 PM #1
I have been given a job to do on Monday and the customer has given this information.
Mitsubishi city multi
r407c
fault code 1005112
I do not know where they got this code from. And the system is on a g50 Central controller.
Any idea?
14-08-2009, 07:46 PM #2
Re: Mitsubishi electric fault code
5112 is fault code for temperature sensor at unit address 100.
All fault codes starting with 51 are for temperature sensors & they will be open circuit or closed circuit to make the fault.
This will be for an outdoor unit or a BC box.
Unusual for any unit to be set at address 100.
Anyway you can use engineers mode at the G50 to see the fault record history & see what units are connected.
Real easy trouble shoot.
Just locate the unit & replace the temp sensor.
14-08-2009, 08:17 PM #3
Thanks for all your help.
Daikin r407c 2 pipe vrv ja fault code any offers?
By Contactor in forum Air ConditioningReplies: 11Last Post: 28-07-2009, 01:26 AM -
Mitsubishi Electric Intermittent fault
By marc5180 in forum Air ConditioningReplies: 28Last Post: 15-01-2009, 10:19 PM -
Fault code for a mitsubishi heavy
By marc5180 in forum Air ConditioningReplies: 7Last Post: 29-02-2008, 08:22 PM -
mitsubishi city multi fault code
By robin r33 gtr in forum Air ConditioningReplies: 5Last Post: 05-11-2007, 10:23 PM -
Mitsubishi SRK 40 HG Fault Code. Help Please.
By smoking_muzzle in forum Air ConditioningReplies: 3Last Post: 11-07-2007, 05:30 PM
