Results 1 to 1 of 1
28-07-2009, 01:46 PM #1
Zanussi ZNB 4051S Cooling problem
I bought this fridge-freezer a couple of years ago, and no problems until 3 weeks ago when my wife gave the fridge a good clean (door open maybe 10 minutes). After that the fridge temperature increased over the next 48 hours from 2 degrees to 9 degrees. I turned off the fridge/freezer for 24 hours to totally defrost and turned on again. No problem for 2 weeks, but now the temperature is increasing again from 2 degrees to 4... and now 5....
Any ideas what the problem might be before I call in the technicians from the Yellow Pages!
Thanks, Jerry
MFI AMP6855 defrost problem
By gliderpilot47 in forum DomesticReplies: 4Last Post: 12-01-2011, 12:11 PM -
problem with GE air con power problem
By Richie101 in forum Air ConditioningReplies: 6Last Post: 05-11-2009, 04:00 PM -
LG heat pump problem
By back2space in forum Heat PumpsReplies: 132Last Post: 01-02-2009, 11:23 PM -
Liquid injection vs thermosiphon oil cooling
By Josip in forum Technical SpeculationsReplies: 25Last Post: 25-07-2007, 09:42 PM -
Regulation of cooling capacity
By npaisnel in forum DomesticReplies: 13Last Post: 08-02-2002, 11:22 PM
