Results 1 to 23 of 23
Thread: Coil Cleaning
28-07-2009, 12:35 AM #1
Coil Cleaning
Hello
I have two seperate rooms. One is set at 45 Degrees F and the other is set for 70 Degrees F.
I have determined that it is time to clean the evaporator coils.
A regular spray bottle will not do as the spray does not penetrate deeper than the first two circuits of the evaporator. I know I can't pressure wash these because it will damage the fins.
What is a feasable way to clean large coils? Method of application/recommended cleaning agent?
The coils have six circuits and are 100% aluminum. R-22 is the refrigerant for both systems.
This will be the first time they have been cleaned.
Thanks!
-FettLast edited by Fett; 28-07-2009 at 12:39 AM.
28-07-2009, 08:25 AM #2
Re: Coil Cleaning
use a spray bottle but use super clean it can be diluted accordingly to an evap or cond and will clear the coil.
once on leave it 5 mins and rinse of with water.
28-07-2009, 10:55 AM #3
Re: Coil Cleaning
Buy a spray bottle that has a pump (pressure pack) and pump to you desired pressure and spray?
28-07-2009, 10:50 PM #4
Re: Coil Cleaning
Hey guys, I have been looking. Here is what I have found.
http://www.nucalgon.com/products/pro...l_cleaners.htm
28-07-2009, 11:18 PM #5
Re: Coil Cleaning
I use CarlyBIo for cleaning evaporators, I have bought a bottle that I can pressurize, like the ones they use in the garden.
Works perfectly
When cleaning a condenser coil I use Carly clean, or when the condensor is realy dirty I tend to use 1/3 of acti brite and water.
29-07-2009, 02:31 AM #6
Re: Coil Cleaning
I am going to get a hand pump sprayer and a 55 gallon drum of something. I have not decided on which coil cleaner to get. I have alot of coils to clean in this place.
02-08-2009, 02:01 PM #7
Re: Coil Cleaning
Hello Fett. I was just looking at the products you have there, and the key is not to get a highly corrosive cleaner. Some solutions are very acidic or very basic. These may clean the fins off very well, but are in essence removing a very small amount of the aluminium itself. I read somewhere you can lose as much as 10% of fin thickness, depending on concentration of mixture. A good neutral cleaner that kills bacteria and removes dirt should be good enough.
04-08-2009, 12:27 AM #8
Re: Coil Cleaning
04-08-2009, 12:36 AM #9
Re: Coil Cleaning
I know Acid will burn you and also Alkaline will burn you.
Question - Will Alkaline damage coils?
04-08-2009, 02:26 AM #10
Re: Coil Cleaning
Hi Fett,
a trick I have found that works really well is to use a non acid /what ever coil cleaner, usual spray pump thing. Drown coil as usual, wait a few minutes and use a air duster gun to blow into coil, wait again and repeat several times. Then you know the cleaner is through coil section total. Rinse with lots of water, run and repeat rinse cycle several times to clear gunge, important to flush drains as well. Nothing worse than a clean coil and a blocked drain situation.
04-08-2009, 05:28 AM #11
Re: Coil Cleaning
a lght brush over in the direction of the fins to remove lint etc before washing will save you time also
05-08-2009, 08:40 PM #12
05-08-2009, 09:46 PM #13
Re: Coil Cleaning
superclean is the mutts nutts,just were gloves
06-08-2009, 01:28 AM #14
Re: Coil Cleaning
gday fett
you could be surprised about whats up there.i prefer the good old garden hose its flushes drains well too-lots of water.i would be doing this as filling up sprayer all the time and its bulk can be a pain.to kill the nasties in the drain afterwards a good dose of diluted household jasol cleaner,its bio degradable,phosphate free non hazardous and comes in different smellsmmm to beer or not to beer...........lets drink breakfast
06-08-2009, 03:02 AM #15
06-08-2009, 05:49 AM #16
Re: Coil Cleaning
apologies fett
i new it was international but only to asia and new zealand it seems.its pretty well an all purpose cleaner not to thin and not gluggy cant really describe it in any other ways.use it for washing hands toommm to beer or not to beer...........lets drink breakfast
12-08-2009, 11:57 PM #17
Re: Coil Cleaning
Fett you can power wash it I have a power washer called coil scrubber uses little water with a wand that can bend 360 deg. it will not bendc fins
http://www.maxi-vac.com/coil_scrubber.htm
check out the Flexible Wand Assembly pules only 18 lbs.
14-08-2009, 01:05 AM #18
16-08-2009, 01:03 AM #19
Re: Coil Cleaning
and dangerous,wonder what the ip rating is!!
16-08-2009, 04:10 PM #20
Re: Coil Cleaning
its not dangerous @ all, not sure why you think it it. We have one and use it all the the is made for coil cleaning only 250 psi. and it will not bend fins
As for the cost it was $450 us when I got mine complete.
19-08-2009, 07:29 PM #21
Re: Coil Cleaning
450 bucks hehe, I think my boss will just give me the birdie for that price.
09-12-2009, 02:44 AM #22
Re: Coil Cleaning
Is it available nwer in Australia ?
10-12-2009, 04:17 AM #23
Re: Coil Cleaning
anyone know its ip rating?
Compressed air for coil cleaning
By Contactor in forum FundamentalsReplies: 12Last Post: 23-05-2009, 03:15 PM -
About 2 stage coil
By cstyx in forum Technical DiscussionsReplies: 3Last Post: 09-04-2009, 08:26 PM -
Dont be shy, advice needed.
By Sledge in forum Air ConditioningReplies: 9Last Post: 27-06-2007, 03:09 PM -
Burst Coil
By frank in forum Air ConditioningReplies: 13Last Post: 20-02-2005, 06:28 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM
