Results 1 to 2 of 2
Thread: LEC Upright freezer model U950WS
16-07-2009, 01:05 PM #1
Hello
I have a LEC upright freezer which is about 10 years old.
When I defrost the freezer, water drips from a wire which runs into the top compartment from the insulation on the top of the machine. When I removed the top cover I found that the insulation at the top of the machine is very wet and that is where the drip is coming from. Can I just let this insulation dry out (will probably take days). It doesn't look like I can remove it to replace it.
Also the spongy insulation has a silver foil/cardboard covering which has perished. Can I just replace with some silver foil. OR is the answer, to go and buy a new unit. Thanks for reading. Geoff.
17-07-2009, 03:18 PM #2
Re: LEC Upright freezer model U950WS
need to buy new one as insulation has failed letting water into it so best to dump and buy new
Hotpoint FZA80P Upright Freezer
By drumtochty in forum DomesticReplies: 9Last Post: 28-01-2008, 04:23 PM -
upright freezer
By sharonrod in forum DomesticReplies: 6Last Post: 30-11-2007, 10:08 AM -
please help with Kenmore Upright Freezer
By lrn376 in forum Trouble ShootingReplies: 0Last Post: 09-07-2006, 10:40 PM -
Brandt Apollo Upright Fridge Freezer
By marto in forum Trouble ShootingReplies: 4Last Post: 06-04-2006, 09:59 AM
