Results 1 to 8 of 8
Thread: Daikin fan prob
15-07-2009, 11:02 PM #1
Daikin fan prob
Hello guys, got a problem with a daikin condenser fan blade. Machine is a 7kw inverter cassette system, 6 months old, don't have details handy. Anyway problem is the condenser fan blade is fouling on the left hand side, against the plastic inner cowling. I went out to it about a month ago and tightened the motor screws up which cured the problem, but still only left 1-2mm clearance on the left hand side of the fan - seemed a bit too close. On the right hand side of the fan there is lots of clearance - a good half inch plus.
The motor bracket must be in the right place as it should be screwed to the coil through the lid? correct me if I am wrong.
Has any body else had this problem? I have to go back to it later this week for the same problem. Or should I just hack some of the plastic inner cowl away.
Andy
15-07-2009, 11:16 PM #2
Re: Daikin fan prob
Is the case actually 'square'?
Maybe the thing has been 'nudged' recently pushing the frame out of shape.Brian - Newton Abbot, Devon, UK
16-07-2009, 12:09 AM #3
Re: Daikin fan prob
Now that's funny.
I had exactly the same problem last week!
The customer called and said that the system lost performance and now didn't cope with the load.
After 10hrs driving up to Scotland this is what I found:
They just "forgot" to tell us that it been hit by a lorry.
The "shelf"/bracket the unit should be standing on is made of 2mm plate!
31-07-2009, 09:37 PM #4
Re: Daikin fan prob
someone appears to have re designed that cage lol
31-07-2009, 10:34 PM #5
Re: Daikin fan prob
It won the "slimmer of the week" award.
The unit managed to slim a whole inch of it's width at the lower fan...Last edited by The Viking; 31-07-2009 at 10:37 PM. Reason: poor englis
01-08-2009, 04:17 AM #6
01-08-2009, 10:24 AM #7
Re: Daikin fan prob
I'd imagine because the bracket was snapped off, the condensor tilted making it out of shape meaning the fan would be catching on the cowel and unit tripping on HP?
Marc
07-08-2009, 04:18 AM #8
Re: Daikin fan prob
Hmmmmmmmmmmmmmmmmm
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin FDYQ250M
By carl in forum Air ConditioningReplies: 7Last Post: 11-08-2009, 12:56 AM -
Daikin AC parts from UK
By skel00 in forum Air ConditioningReplies: 5Last Post: 05-04-2009, 01:24 PM -
Fixing Daikin A3 Error
By Stuffy in forum Air ConditioningReplies: 3Last Post: 27-03-2009, 06:02 AM -
Daikin Comp and inverter
By WCC73 in forum Air ConditioningReplies: 5Last Post: 08-11-2008, 08:44 PM
