24-05-2001, 03:34 PM #1
Had a Manitowoc call yesterday. I'm not exactly an ice machine expert, but here's what I found.
The unit was down, shut off at the ice-off-wash switch.
No codes on the board. So I started it up.
A good start-up, till slush began forming in the trough to where it blocked the water thru the pump.
I have not encountered this before.
What do you guys think?
28-05-2001, 04:20 PM #2
Slushing is fairly normal...
...says Manitowoc factory. So I was barking up the wrong tree chasing a cat that wasn't even there in the first place.
Someone had turned the unit off because it was heating up a small kitchenette room in a building that was suffering from lack of cooling because of a DDC system malfunction.
Also, the ice probe was out of adjustment, and the water level slightly high to where it ran out of the standpipe sometimes.
And someone had turned the water to the unit down to a trickle.
And that, as Paul Harvey says, is the rest of the story.
08-05-2008, 05:38 AM #3
Re: Manitowoc Q series slush in trough
maybe someone turned it off. there is no manitowoc ice machine that would automatically put the ice/off/swith to off.
please make your findings clear?
do you mean that there is no water coming in the water through? or there is water in the water trough but the pump is not pumping the water to water curtain?With great power Comes Great Responsibility
08-05-2008, 09:42 AM #4
08-05-2008, 01:01 PM #5
08-05-2008, 01:14 PM #6
waaaa i see it..
the date of post, sorry i feel sleepy.
very tired in working.With great power Comes Great Responsibility
Manitowoc Ice machine taking too long to harvest..
By nyTroX in forum Trouble ShootingReplies: 26Last Post: 08-05-2011, 09:39 PM -
New to RE and needing Daikin Help
By Owen in forum Air ConditioningReplies: 20Last Post: 25-09-2008, 06:55 PM
