Thread: Daikin Noisy Drip Tray Pump
29-06-2009, 09:34 AM #1
Hello I hope somebody can help. I have moved into a flat that has 3x Daikin FT25GZVINB and 1 x FT35JZVINB, they chill very well, but two of the unuts ( in the main bedroom and lounge inevitably!) Have very loud drip tray pumps that are so load as to make the units unusable. Has anybody come across this problem? is it possible to drain the drip tray to a tank and therefore not need the pumps? Or is this a common problem and new pumps will fix?
29-06-2009, 05:37 PM #2
29-06-2009, 11:28 PM #3
Re: Daikin Noisy Drip Tray Pump
Those units do not have a built in drain pump, they have an additional pump to remove the water.
New pumps may fix it as long as good quality ones are used.
In the short term you might be able to use the gravity drain hose from the units and drain it into a bucket until you have the pumps resolved.Brian - Newton Abbot, Devon, UK
Noisy Daikin VRVIII 3 pipe BSVQ boxes
By hyperion in forum Heat PumpsReplies: 24Last Post: 25-02-2010, 01:49 PM -
Daikin lift pump
By Slim R410a in forum Air ConditioningReplies: 10Last Post: 13-07-2009, 11:12 PM -
SILENCER FOR NOISY Payne HEAT PUMP
By RODA in forum Heat PumpsReplies: 2Last Post: 24-02-2009, 04:22 PM -
DAIKIN Drain Pump
By 2007eng in forum Air ConditioningReplies: 23Last Post: 03-04-2008, 01:54 PM -
Daikin drip tray
By Andy AC in forum Air ConditioningReplies: 2Last Post: 08-11-2007, 08:55 PM
