Thread: Renault AC compressor
16-07-2004, 12:04 PM #1
In a recent folder of Renault cars, they say that their newest models like the Espace have in their AC system a variable piston compressor which is electronicaly controlled.
What is this exactly?
Question for Karl perhaps?
16-07-2004, 12:06 PM #2
Re: Renault AC compressor
Yeh I'd like to know that one as well, my Peug has one on the climate control package to.
16-07-2004, 01:22 PM #3
Hi Peter, Jon.
I want to give it a try.
Most car AC compressors have 5 to 7 pistons, a plate, behind the pistons located in an angle and when it turns, the pistons move forward and backward.
In hydraulic high pressure oil pumps, used in agriculture ( Tractors) the working principal is almost the same, apart from the angle of the plate which is variable controlled by the pressure, i.e. when there is no need for high pressure, the plate is almost 90 deg. to the shaft and when high pressure is needed, the plate changes the angle and the piston volume gets bigger.
I will dare and say that this is the case here.
I also would like to hear Karl's prognosis on the subject.
The link will show you how these pumps work with variable displacement.
http://www.parker.com/pumpmotor/cat/...h/1553a003.pdf
Chemi
16-07-2004, 03:14 PM #4
Chemi got it in one! If the compressor number has a "V" in it then it is variable, Sanden SD7V16, or Harrison/Delphi V5 etc
Stuff like Skoda Fabias and the baby Mercs have a compressor that runs constantly, even when switched off. A valve controlled by the ECU adjusts the refrigerant flow and either directs it to the TXV or simply circulates it round the compressor. If the compressor should fail, then there is still a shear mechanism on the belt pully, so at least it will still get you homeKarl
16-07-2004, 04:20 PM #5
Thanks Karl.
Those gray cells still move.
Chemi
16-07-2004, 09:52 PM #6
Originally Posted by chemi-cool
LOL those little grey cells need lubrication though...You have earned yourself a pintKarl
can overfilling/overcharging damage a compressor?
By fredjchavez in forum Trouble ShootingReplies: 10Last Post: 12-02-2009, 10:30 AM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM -
One Half of a Part Wound Compressor Motor is Burnt
By aygul in forum Trouble ShootingReplies: 2Last Post: 25-08-2003, 11:11 AM -
Compressor failure...... cause
By herefishy in forum Technical SpeculationsReplies: 8Last Post: 06-12-2002, 12:15 AM -
Starting a compressor, and receiver questions.
By DaBit in forum Technical SpeculationsReplies: 9Last Post: 24-08-2002, 12:37 PM
